Here's a quick video of a project I started last night. In a nutshell, I added Ethernet to my garage (using a TPLink powerline adapter), and then added a screen to my touchscreen project at home.
Video demo of HSTouch launching Foscam Pan & Tilt Preset
Very nice! So what are the specs of hs server? Or better yet what kind of Hardware specs do you need to run at least 4 of these cams
Sent from my iPhoneTom
Originally posted by TomTom View PostVery nice! So what are the specs of hs server? Or better yet what kind of Hardware specs do you need to run at least 4 of these cams
Sent from my iPhone
Thanks Mark! I'm not going to display 4 cams at the same time, only one at a time, but just wondered if the current pc I'm using, mini itx - 1.2 ghz celeron, 2gb of ram, will be able to handle 4 cams. My thought is to perhaps make this my vacation home hs server and get another hs server for the regular house. Also have you tested these cams on a zee 2? Any issues, limitations?
Originally posted by mwaite View PostIs the ~1.5 frame/sec because of the TPLink?
Originally posted by TomTom View PostThanks Mark! I'm not going to display 4 cams at the same time, only one at a time, but just wondered if the current pc I'm using, mini itx - 1.2 ghz celeron, 2gb of ram, will be able to handle 4 cams. My thought is to perhaps make this my vacation home hs server and get another hs server for the regular house. Also have you tested these cams on a zee 2? Any issues, limitations?
Sent from my iPhone
In my testing, with one Android client and using Ethernet, I can get 10+ frames/sec on a Zee S2. Each frame is only 36K bytes and the Zee can move data pretty quickly, that's all its doing in this case. The frame rate will drop going through MyHS, but that's because of the network path.
On Windows or an SEL, 15 frames/sec is not a problem. As Mark said, in our office we have 6 clients displaying video from a single camera. I don't see any degradation on the Ethernet connected clients. The wifi ones don't like to share the wifi, but this is not a typical case. What is more typical would be to display maybe 4 cameras at the same time. I think the frame rate would still stay pretty high, the bottleneck there would be the client since it has to display them all.
