I have just started playing around with homeseer and my rfxtrx. I have a NEXA door sensor which I'm trying to get to work with this. I have installed the plug-in in the trial version of homeseer. When trying to add the door sensor device I get "no devices found" under the input devices section of the plug-in configuration screen. Also, I do not see anything in the log even though I have set the logging level as high as it goes. I get a number of entries that seem unrelated
30.07.2013 08:49:48 - RFXCOM - (RecTRXChar) transceiver #1 packet: 0D00000A02000000000000000000
30.07.2013 08:49:48 - RFXCOM - (RecTRXChar)Unknown Packet type:0
30.07.2013 08:53:18 - RFXCOM - (RecTRXChar) Unknown packet.
These log entries do not correspond with me triggering the sensor, and the number in the first message does not correspond with what I see in rfrxmngr. rfxmngr gives me a very reasonable log message which indicates that the hardware side of this works:
0B11000A00837F3E0A010F70
Packettype = Lighting2
subtype = AC
Sequence nbr = 10
ID = 0837F3E
Unit = 10
Command = On
Signal level = 7
I have enabled AC and X10 in the settings menu in both the applications. Do you have any ideas why homeseer is not reading the packets correctly?
subtype = AC
Sequence nbr = 10
ID = 0837F3E
Unit = 10
Command = On
Signal level = 7
