Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Software > HS3 / HS3PRO > HS3 / HS3PRO Discussion
HS3 / HS3PRO Discussion Discussions related to the released version of HS3/HS3PRO
Old April 19th, 2014, 08:11 AM
cthibaud cthibaud is offline
Circles RECCURING event for Node X, but the device doesn't exist on the zwave network????????
Hi guys,
I receive regularly (several per day) messages (in the log) like this one for different Nodes number:
Z-wave error~!~Node Event for Node 8 on Network 0XYZABCD, CC=COMMAND_CLASS_SWITCH_MULTILEVEL_V2 but no valid devices where found
It appears for Node 8, 14, 26, 74, 138, 202, ...
I know many threads are already opened around this kind of problem, but apparently mine is different:
This Nodes don't exists on my Aeon Labs Z-Stick if I navigate to PLUG-INS\Z-wave\Node Information and check that numbers.
And if I navigate to PLUG-INS\Z-wave\Controller Management, in the Controller Node Information, I also see the list of Nodes in the Controller which are the same than the previous operation just above.
So finally, I receive information from Node that don't exist on my stick???
Of course, I have already done several and several tests. I have only one stick and one zwave network. I tried optimazation, full optimization, rescan, ....
My problem is with HS3 (3.0.0.68), I migrated 3 months ago and before with the same stick on HS2, I didn't received errors like that.
Anyone an idea????
Old April 23rd, 2014, 12:11 PM
Any idea?
Old May 4th, 2014, 04:24 AM
for information, the problems are resolved with the update of homeseer version 3.0.0.68 and zwave plugin version 3.0.0.136.
No more errors like describe above
Move Device from Zwave Network A to Network B burkeden HomeSeer Z-Wave Plug-in 2 December 13th, 2013 01:06 PM
Replacing zwave device that doesn't work Rotech HomeSeer Z-Wave Plug-in 12 February 17th, 2013 08:29 PM
COM Port 4 doesn't exist???? tblackmon9599 HS2 / HSPRO 1 March 13th, 2011 11:32 AM
Node removal status: Failed, node may still exist kenflorian HomeSeer Z-Wave Plug-in 5 May 9th, 2007 08:46 AM
help with new reccuring event collegeboyslive HomeSeer General Discussion Area 1 August 29th, 2005 01:03 PM
