I need some questions answered to find the right and fastest approach to stuff.
Please correct me if i have got it all wrong.
When integrating a z-wave module you do so by adding to the usb-stick and into HS. And you can use Z-Tool to add also in a more easy way, with a laptop then plug the usb stick into HS system again.
But all modules will always be stuck in the usb stick right? Not in the system?
So lets say i have a system home. i want to add some stuff to the system at the cabin. How can i save time? Could i have a "test" stick that i could add all the new modules home, bring the modules to the cabin and then transfer from one stick to another? Is this possible?
I just want to find a way for the easiers way of integration. I think i will buy the Z-Tool if recommended so i can save some time with that at least when setting it up.
