I added the following the Alex Kurz's event scripts. I wanted a way to not include certain entire house codes (such as dusk/dawn detectors). Replace the device string build section with this...Works good for me...
For i = 1 to DevCount
set device = hs.GetDevice(i)
If i = 1 Then
CallString = device.location & " " & device.name
Else
Select Case Left(hs.GetDeviceCode(device.location & " " & device.name), 1)
'Change the following statement to reflect the house codes to ignore
Case "K", "M", "z", "t", "["
dvcode = EE
Case Else
CallString = CallString & "|" & device.location & " " & device.name
End Select
End If
Next
If i = 1 Then
Else
dvcode = EE
Case Else
End Select
End If
Next
