SqueezeBox plugin V2.1.0 beta
    #31
    Please see this thread for my question about stops in the audio with the latest beta:
    http://board.homeseer.com/showthread.php?p=1009911
      #32
      Originally posted by markus.bergvoll View Post
      Finally i got around to test the new Beta.
      Looks better indeed, but still a couple of comments. Sorry..
      Playlists, can you do the same magic you did with "Whats new?" This will solve the max 3 levels problem.
      ie: Playlists - Background music
      "Top 100 Tracks" work, but the one called "top 100" does not list anything.
      In "Genres", is there some way i can change your default names like LMS_MyApps? Would be nice to call it something more friendly.
      Do you know if its possible to change sort order in listboxes for IOS?
      And finnaly - While your solution to the max levels problem is good - Is there somehow a way we can convince Homeseer to expand on this? Do you as a developer have more influence on this than us?
      Playlists should include the one level flattened organization, See the screenshot below from one of may HSTouch screens.
      You cannot currently change the root names (LMS_MyApps, etc). I am open for any suggestion to better name them. Not sure if I can make them user selectable without too many side effects (while the system/HSTouch is already running).
      I am not sure if you can change the list box sort order in HSTouch especially for Music entries.
      On the last subject, I collected notes and suggestions how to make the Music API more flexible including navigation to arbitraty depth. I was plan to send it to HomeSeer, but have not done so yet.
        #33
        Originally posted by Moskus View Post
        It seems like Music API just stopped. The current playlist box in HStouch is empty, and my textboxes with Track Title, Artist name, etc are not updating...
        It happened again!
          #34
          Moskus:
          Are you using Spotify?
          If yes, make sure that you are using the Triode third party Spotify plugin not the Logitech plugin.
          http://forums.slimdevices.com/showthread.php?t=79706
          The SqueezeBox plugin doesn't work with the Logitech Spotify plugin and besides the Triode version is much better.
          DSteiNeuro
          HS3Pro
          Enabled Plug-Ins
            #35
            Originally posted by DSteiNeuro View Post
            Moskus:
            Yes. And yes.
            I have Duet so the only way to make Spotify work on that is to use Triodes plugin...
              #36
              It happened again!
              This happens to me too.
              Also, no flattened playlist or lbrary while it works.
                #37
                Markus, which beta version of the plugin are you using?
                  #38
                  I'm using the beta 3. Will try beta 4 tomorrow.
                    #39
                    Hi PCP,
                    I've asked Rich in the past whether this embedded navigation behavior can be made configurable, as in put in an .ini file the different selections and the relation between them. I struggle with the same limitations on my Sonos and DLNA plug-ins. Having two (minor) changes would already help a lot:
                    1. Is to make the start selection configurable (tracks, genre, album, artist, playlist) so you can add radiostations, audiobooks, podcasts ...
                    2. Have the plugin return to the calling HS server whether it reached the lowest level of navigation (meaning if you click on it now it will play rather then select to next level) so you can go deeper than the current implementation
                    Let me know if I can help, hope HS3 will have improvements in this area but I'm not holding my breath.
                    Dirk
                    Maybe we should
                      #40
                      MP3 option in TTS speech proxy
                      How do I send/play mp3 soundfiles for announce in V2.1.0.4, and how fast respond is it. I would like to use the function for doorbell etc. Have a large squeezebox network. Right now I'm using hs-speaker for announce.
                      "Option in plugin configuration page to use mp3 files in the TTS speech proxy"
                      Tasker Plugin / Speech Droid
                      Tonlof | Sweden
                        #41
                        I to would like to get this to work.
                        I have a tick in Enabled Speak Proxy and Use MP3.
                        I have the speak volume on the player at 50 and the main volume at 50 but i don't get anything.
                        Greig.
                        Scripts =
                        Various
                          #42
                          If your goal is to play some sound (mp3), the easiest is to pick a song (or natural sounds / effect) from your LMS library and use the HS2 SqueezeBox plugin APIs / Music APIs to play this sound from your library on the desired players. If you want to speak text on SqueezeBox player, you should us the plugin built in TTS.
                          If you want to do both, i.e. play a sound followed by text to speak, you can create an event with two speak actions: the first to play a wav file (if I recall, it only accepts wav files) and the second for the text to speak. The SqueezeBox plugin will convert the wav file to an mp3 before playing it on the players if option "use mp3" is selected.
                            #43
                            Originally posted by dcorsus View Post
                            Hi PCP,
                            Dirk
                            Maybe we should
                            I was planning to do a writeup this weekend but last week's travel with cancelled flights and delays decided otherwise.
                            Anyways stepping back, I believe the music browsing/playing APIs could be made much more generic (i.e. take a level of abstraction) without introducing the specific notion of artists, albums, radios, etc.
                            I could imagine we could have only one API to browse the content that would return an array of structures with key/value/isMusic/hasChildren entries. The isMusic would be a boolean to indicate if the node can be played (does not have to be a leaf). hasChildren would be a boolean as well and would indicate it this is the leaf of the tree (tracks typically). This music API to browse would use one argument (maybe another for the player id/name): the parent key for which to browse children nodes ; the parent node could be null/empty if this is the top node (i.e. albums, artists, as desired by the plugin developer). The API to play music would also take the key argument specifying the music to play (instead of genre, etc currently). Whoever builds music plugin would then have to manage the key as best suited for his application (which could be a hash key, a database key, a dot separated node id list, etc). I believe this could make the music browsing APIs quite abstract / generic and provide the breadth (radios, podcasts, movies, etc) and the depth browsing we are looking for.
                              #44
                              I'm now running the latest beta (4) and it looks pretty good!
                              I do, however, have some small comments:
                              - Do the device type have to be named "Device Type"? We know it's a device type, it says so on the column name. The field could just say "Squeezebox".
                              - Why can't devices I choose to hide stay hidden? They tend to forget that they're hidden for some reason.
                              - It seems like my mysterious "Disconnect" message still sometimes show up, but most of the time, the music doesn't stop playing. Great!
                                #45
                                Great news!
                                When you say "They tend to forget that they're hidden for some reason", when do they tend to appear again? Is it when you restart HS2 or at other times?
                                Good point about the device type! Not sure if I can change this without impact much existing installations, I will have to check.
