Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > stefxx Plug-Ins
stefxx Plug-Ins Plug-Ins by stefxx
Old July 1st, 2015, 03:28 AM
Malosa's Avatar
Malosa Malosa is offline
Super Seer
False alerts (maybe bug ? )
I was getting a message today thats gonna raing , but that dont happen because its gonna be to hottest summer day today haha
Verwachte Regen
Start: 00:00
Stop: Unknown
Intensity: Light
Average: 0.04 mm/h
Maximum: 0.15 mm/h
Today 09:36:43
Can u check the code , because its saying its gonna rain , even on buienradar says no rain for 3 hours (on location) and on my coordinates , i double checked the input and coordinates ....
kind regards
HS3Pro 3.0.0.435 on windows 7 ultimate X64 on hp quadcore laptop 8 GB. 687 Devices, 480Events
Old July 1st, 2015, 05:02 AM
stefxx's Avatar
stefxx stefxx is offline
I am confident this is the data I get from Buienradar. Even on the hottest day of the year sometimes Buienradar does predict a very tiny little bit of rain, and by the next update it is gone again. And 0.04mm of rain p/hour is basically no rain at all :-)
If you don't trust it, please enable the debug options and when it happens again we can see what data was pulled from Buienradar.
I had the same happening this morning three times already, here is one example:
1-7-2015 10:40:34: 000|10:30 024|10:35 043|10:40 051|10:45 047|10:50 030|10:55 000|11:00 000|11:05 000|11:10 000|11:15 000|11:20 000|11:25 000|11:30 000|11:35 000|11:40 000|11:45 000|11:50 000|11:55 000|12:00 000|12:05 000|12:10 000|12:15 000|12:20 000|12:25 000|12:30
And 5 minutes later it was gone:
1-7-2015 10:45:34: 000|10:35 000|10:40 000|10:45 000|10:50 000|10:55 000|11:00 000|11:05 000|11:10 000|11:15 000|11:20 000|11:25 000|11:30 000|11:35 000|11:40 000|11:45 000|11:50 000|11:55 000|12:00 000|12:05 000|12:10 000|12:15 000|12:20 000|12:25 000|12:30 000|12:35
stefxx
Old July 1st, 2015, 09:12 AM
Malosa's Avatar
Super Seer
yeah ove seen it u right
buienradar is very accurate !
thanks for the reply !
Have a nice day and enjoy the nice summer weather !!
Old July 4th, 2015, 01:52 AM
John245 John245 is offline
Hi Steff,
Indeed it is not a bug sometimes rain is expected according to the data retrieved by the PI. Although the Buienradar website does not show this rain in the graph. I think the Buienradar site has some logic to determine if the expected rain is a false positive prediction.
I think it will be help-full if you can also trigger on the average amount of rain expected (in combination with the amount of rain) to minimize the false positive result. Is it possible to add this trigger?
John
Old July 4th, 2015, 03:58 AM
stefxx's Avatar
Ok, let's see what we can do. We need some kind of threshold to avoid these "false positives" (I don't really think they are, if you zoom enough on the buienradar map you sometimes see little rain areas even on the hottest day of the year). Anyway, I agree it can be annoying. And I assume we are referring here to the announcement (by the speaker client) of precipitation by the plugin?
A threshold can be either in time (for instance, only trigger after receiving two positives) or value (only trigger when precipitation expected is more than xx mm). I think the last is the best, as I don't want to delay precipitation expectancy unnecessary.
If you look at the example above where you see some precipitation expected on a very hot day, the highest value is 51, which equals 0,01539 mm of rain (per hour, so this single 5 minute timeframe is only 0,0013 mm). Which is next to nothing. Perhaps I should build a (configurable?) threshold on that value?
Old July 22nd, 2015, 01:25 PM
stefxx's Avatar
No response anymore. I guess this is not really an issue after all. I will not change the logic for now as the interest seems low...
Old July 22nd, 2015, 03:51 PM
It is an issue for me and I will appreciate if you add a Trigger based on the average amount of rain expected. I"m controlling my awnings based on the information of the PI. But it. Seems that I"m the only one
John
Verzonden vanaf mijn iPhone met behulp van Tapatalk
Old July 22nd, 2015, 04:21 PM
stefxx's Avatar
John, I think you can already create such a trigger right now. Unless you mean something else with "average"?
Let's assume you want to close your awnings when precipitation is expected in the next 10 minutes, create an event like this:
IF Minimum 0,2 mm per hour or more precipitation expected between now and the next 10 minutes at (your location).
Just select the "correct" minimum amount to avoid false positives.
Old July 22nd, 2015, 11:58 PM
Sref,
I did the trick below and it seems to solve the issue.
IF Minimum 0.05 mm per hour or more precipitation expected between now and the next 30 minutes at xxxxxxxx
AND IF Awning Kitchen Canopy has a value equal to Down
AND IF Minimum 0.1 mm in total or more precipitation expected between now and the next 60 minutes at XXXXX
Then Run Event Awning Awning up
HTML code is On
RF false alarm? LeoS Vista Alarm Plug-in (3P) 12 May 16th, 2015 12:11 PM
False trigger??? Rotech Kinect (3P) 1 January 18th, 2015 10:12 PM
False Trips Vantage2 JV Caddx Plug-In 13 January 28th, 2007 12:41 AM
<% Response.Write hs.GetPageHeader("Calender",""," ",False,False,False,False,False) MeSteve Script & Plug-In Development 5 December 5th, 2005 10:21 AM
