Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > stefxx Plug-Ins
stefxx Plug-Ins Plug-Ins by stefxx
Old August 29th, 2016, 04:47 PM
The-Source The-Source is offline
Seer Plus
Buienradar Incorrect amount of data received
I saw this today in my log and dont know how longs its going, not more then a few days ... The initializing and shutting down of the plugin are manual restarts which i tried before opening the thread
aug-29 22:59:47 Plug-In Shutting down Plug-In: Buienradar
aug-29 22:59:38 Buienradar Incorrect amount of data received from Buienradar: 000|22:55 000|23:00 000|23:05 000|23:10 000|23:15 000|23:20 000|23:25 000|23:30 000|23:35 000|23:40 000|23:45 000|23:50 000|23:55 000|00:00 000|00:05 000|00:10 000|00:15 000|00:20 000|00:25 000|00:30 000|00:35 000|00:40 000|00:45 000|00:50
aug-29 22:59:08 Buienradar Incorrect amount of data received from Buienradar: 000|22:55 000|23:00 000|23:05 000|23:10 000|23:15 000|23:20 000|23:25 000|23:30 000|23:35 000|23:40 000|23:45 000|23:50 000|23:55 000|00:00 000|00:05 000|00:10 000|00:15 000|00:20 000|00:25 000|00:30 000|00:35 000|00:40 000|00:45 000|00:50
aug-29 22:58:38 Buienradar Incorrect amount of data received from Buienradar: 000|22:45 000|22:50 000|22:55 000|23:00 000|23:05 000|23:10 000|23:15 000|23:20 000|23:25 000|23:30 000|23:35 000|23:40 000|23:45 000|23:50 000|23:55 000|00:00 000|00:05 000|00:10 000|00:15 000|00:20 000|00:25 000|00:30 000|00:35 000|00:40
aug-29 22:58:08 Plug-In Finished initializing plug-in Buienradar
aug-29 22:58:08 Buienradar Incorrect amount of data received from Buienradar: 000|22:45 000|22:50 000|22:55 000|23:00 000|23:05 000|23:10 000|23:15 000|23:20 000|23:25 000|23:30 000|23:35 000|23:40 000|23:45 000|23:50 000|23:55 000|00:00 000|00:05 000|00:10 000|00:15 000|00:20 000|00:25 000|00:30 000|00:35 000|00:40
aug-29 22:58:07 Buienradar Initializing plugin Buienradar version 3.0.0.19
aug-29 22:58:06 Info Plugin Buienradar has connected. IP:127.0.0.1:51047
Old August 30th, 2016, 03:24 AM
stefxx's Avatar
stefxx stefxx is offline
I noticed the same issue this morning (between 6:00 and 6:35) but it seems to be resolved now. It seems a temporary issue at the buienradar site.
I will look into the number of log entries when such an error occurs later. I agree it is a bit much.
stefxx
Old August 31st, 2016, 02:30 PM
Seer Plus
Still get it with a 30s interval:
aug-31 20:46:11 Buienradar Incorrect amount of data received from Buienradar: 000|20:45 000|20:50 000|20:55 000|21:00 000|21:05 000|21:10 000|21:15 000|21:20 000|21:25 000|21:30 000|21:35 000|21:40 000|21:45 000|21:50 000|21:55 000|22:00 000|22:05 000|22:10 000|22:15 000|22:20 000|22:25 000|22:30 000|22:35 000|22:40
aug-31 20:45:41 Buienradar Incorrect amount of data received from Buienradar: 000|20:45 000|20:50 000|20:55 000|21:00 000|21:05 000|21:10 000|21:15 000|21:20 000|21:25 000|21:30 000|21:35 000|21:40 000|21:45 000|21:50 000|21:55 000|22:00 000|22:05 000|22:10 000|22:15 000|22:20 000|22:25 000|22:30 000|22:35 000|22:40
aug-31 20:45:11 Buienradar Incorrect amount of data received from Buienradar: 000|20:45 000|20:50 000|20:55 000|21:00 000|21:05 000|21:10 000|21:15 000|21:20 000|21:25 000|21:30 000|21:35 000|21:40 000|21:45 000|21:50 000|21:55 000|22:00 000|22:05 000|22:10 000|22:15 000|22:20 000|22:25 000|22:30 000|22:35 000|22:40
aug-31 20:44:41 Buienradar Incorrect amount of data received from Buienradar: 000|20:45 000|20:50 000|20:55 000|21:00 000|21:05 000|21:10 000|21:15 000|21:20 000|21:25 000|21:30 000|21:35 000|21:40 000|21:45 000|21:50 000|21:55 000|22:00 000|22:05 000|22:10 000|22:15 000|22:20 000|22:25 000|22:30 000|22:35 000|22:40
aug-31 20:44:11 Buienradar Incorrect amount of data received from Buienradar: 000|20:45 000|20:50 000|20:55 000|21:00 000|21:05 000|21:10 000|21:15 000|21:20 000|21:25 000|21:30 000|21:35 000|21:40 000|21:45 000|21:50 000|21:55 000|22:00 000|22:05 000|22:10 000|22:15 000|22:20 000|22:25 000|22:30 000|22:35 000|22:40
with 3.0.0.19 now trying the updated version
with 3.0.0.20 i still get the same errors in my log
aug-31 20:50:54 Buienradar Incorrect amount of data received from Buienradar: 000|20:45 000|20:50 000|20:55 000|21:00 000|21:05 000|21:10 000|21:15 000|21:20 000|21:25 000|21:30 000|21:35 000|21:40 000|21:45 000|21:50 000|21:55 000|22:00 000|22:05 000|22:10 000|22:15 000|22:20 000|22:25 000|22:30 000|22:35 000|22:40
aug-31 20:50:24 Buienradar Incorrect amount of data received from Buienradar: 000|20:45 000|20:50 000|20:55 000|21:00 000|21:05 000|21:10 000|21:15 000|21:20 000|21:25 000|21:30 000|21:35 000|21:40 000|21:45 000|21:50 000|21:55 000|22:00 000|22:05 000|22:10 000|22:15 000|22:20 000|22:25 000|22:30 000|22:35 000|22:40
aug-31 20:49:54 Buienradar Incorrect amount of data received from Buienradar: 000|20:45 000|20:50 000|20:55 000|21:00 000|21:05 000|21:10 000|21:15 000|21:20 000|21:25 000|21:30 000|21:35 000|21:40 000|21:45 000|21:50 000|21:55 000|22:00 000|22:05 000|22:10 000|22:15 000|22:20 000|22:25 000|22:30 000|22:35 000|22:40
Old August 31st, 2016, 02:54 PM
stefxx's Avatar
It will keep retrying every 30 seconds. I did not change that. But after 5 attempts it should stop logging for 15 minutes. Unless you have "general debug logging" turned on (which will flood your log anyway, regardless of an error condition).
I will look into the source of the error later (it seems Buienradar did change the API but it is not very consistent yet) but that will take time and I want to make sure it is not a temporary situation that I am trying to fix.
Old September 1st, 2016, 01:19 PM
stefxx's Avatar
Version 21 is in the updater. Should be able to cope with the API changes. Testing is limited, but as the current version doesn't seem to work at all, I guess this is better anyway
Let me know if there are any issues.
Old September 2nd, 2016, 01:48 PM
Seer Plus
The log doesn't show any errors anymore. So it seems you fixed it the right way
Old September 26th, 2016, 01:37 PM
Seer Plus
New error occurred today:
sep-26 19:41:41 Buienradar Error resolved. Last error: Incorrect amount of data received from Buienradar: (first occurrence at 26-9-2016 19:35:41)
sep-26 19:37:41 Buienradar Too many consecutive errors detected, error logging interval reduced to every 15 minutes...
sep-26 19:37:41 Buienradar Incorrect amount of data received from Buienradar:
sep-26 19:37:11 Buienradar Incorrect amount of data received from Buienradar:
sep-26 19:36:41 Buienradar Incorrect amount of data received from Buienradar:
sep-26 19:36:11 Buienradar Incorrect amount of data received from Buienradar:
sep-26 19:35:41 Buienradar Incorrect amount of data received from Buienradar:"
I just came to watch to log for some other things and then noticed this..
Old September 26th, 2016, 01:39 PM
stefxx's Avatar
How is this a new error? It is just the Buienradar API that is not very stable lately...
HTML code is On
Buienradar success? Otto-mation stefxx Plug-Ins 2 August 5th, 2016 04:19 PM
Incorrect data retrieved by plugin from IAMs scorbett HomeSeer Current Cost Envi Plug-in 4 October 11th, 2011 06:44 PM
VWS plug-in returning incorrect data george_holmes VWS 3 February 2nd, 2011 03:39 PM
PLCBUS Error : Incorrect data length received David_H PLCBUS Connector 15 March 16th, 2009 03:55 PM
serial port data received script JPlatt50 Script & Plug-In Development 1 August 28th, 2004 12:27 PM
