Hello,
Thank you for the great plugin. I'm on my trial period and have some difficulties controlling some of my devices.
Configuring the hub, activities and devices went pretty well. I can switch between my activities without any problems. All of my devices are created and have drop down menus with their controls.
I have a problem with one generic LED light strip, which is being controlled by the Harmony. It has controls like Power Toggle, Light 1, Light 2, Scene 1, Scene 2, etc. All these controls are visible from HomeSeer, however the only working are Lights and Scene ones. The Power Toggle is not working - although it works from the remote and the Android app. I checked if the IR is blinking /with a camera pointed to it/ while the power toggle is chosen from the drop down and it's not. So HomeSeer just doesn't send the command.
I have absolutely the same issue with Fujitsu AC control - have to commands learned 24 degrees auto and 30 degrees high - working fine from the remote and app, but not working from HomeSeer.
It seems, that all my other commands are working as expected.
Please note, the commands for the AC and LED strips are learned from the original remotes.
Tried restarting the plugin, Homeseer, rescan of activites - nothing helped.
Tried firing the command from event - again no luck.
Log:
For example, Scene 3, Light 1 are working, Power Toggle is not. I cannot find any difference in the log...
Details about my setup - still testing:
Current Date/Time: 27-Oct-16 11:29:08 PM
HomeSeer Version: HS3 Standard Edition 3.0.0.297
Operating System: Microsoft Windows 8.1
System Uptime: 0 Days 0 Hours 17 Minutes 41 Seconds
IP Address: 192.168.1.149
Number of Devices: 25
Number of Events: 6
Available Threads: 800
Enabled Plug-Ins
2.0.10.0: BLUSBUIRT
3.0.0.31: EnvisaLink
3.6.0.0: Harmony Hub
3.0.0.68: HSTouch Server
3.0.0.45: Kinect
3.0.1.87: Z-Wave
Log:
Oct-27 23:17:53 Harmony Hub Plugin: Harmony Hub Test RunDeviceCommand for Hub1 DeviceID: 38754840 Command: Power Toggle
Oct-27 23:17:53 Harmony Hub Plugin: Harmony Hub CAPIcontrol values: Hub1-Logitech Harmony Hub Device-1-RGB led Generic-38754840-Power Toggle
Oct-27 23:17:50 Kinect TRACE Phrase rejected =
Oct-27 23:17:50 Harmony Hub Plugin: Harmony Hub Test RunDeviceCommand for Hub1 DeviceID: 38754840 Command: Light1
Oct-27 23:17:50 Harmony Hub Plugin: Harmony Hub CAPIcontrol values: Hub1-Logitech Harmony Hub Device-2-RGB led Generic-38754840-Light1
Oct-27 23:17:50 Kinect TRACE Phrase hypothesized = Alexa, Confidence=0.01871934
Oct-27 23:17:50 Kinect TRACE Speech Detected:
Oct-27 23:16:34 Harmony Hub Plugin: Harmony Hub Update Activity reference/status is : 16----Hub1=2
Oct-27 23:16:34 Harmony Hub Plugin: Harmony Hub reference/status is : 16--Watch TV--Active--2
Oct-27 23:16:34 Harmony Hub Plugin: Harmony Hub Test Get Active Activity output for:Hub1: 19365576 -
Oct-27 23:16:00 Harmony Hub Plugin: Harmony Hub Test RunDeviceCommand for Hub1 DeviceID: 34873742 Command: 24 auto
Oct-27 23:16:00 Harmony Hub Plugin: Harmony Hub CAPIcontrol values: Hub1-Logitech Harmony Hub Device-1-Fujitsu Climate Control-34873742-24 auto
Oct-27 23:16:00 Event Event Trigger "Test test AC 24 auto"
Oct-27 23:13:03 Harmony Hub Plugin: Harmony Hub Test RunDeviceCommand for Hub1 DeviceID: 34873742 Command: 24 auto
Oct-27 23:13:03 Harmony Hub Plugin: Harmony Hub CAPIcontrol values: Hub1-Logitech Harmony Hub Device-1-Fujitsu Climate Control-34873742-24 auto
Oct-27 23:12:57 Harmony Hub Plugin: Harmony Hub Test RunDeviceCommand for Hub1 DeviceID: 38754840 Command: Power Toggle
Oct-27 23:12:57 Harmony Hub Plugin: Harmony Hub CAPIcontrol values: Hub1-Logitech Harmony Hub Device-1-RGB led Generic-38754840-Power Toggle
Oct-27 23:12:20 Harmony Hub Plugin: Harmony Hub Test RunDeviceCommand for Hub1 DeviceID: 38754840 Command: Scene3
Oct-27 23:12:20 Harmony Hub Plugin: Harmony Hub CAPIcontrol values: Hub1-Logitech Harmony Hub Device-7-RGB led Generic-38754840-Scene3
Number of Events: 6
Enabled Plug-Ins
2.0.10.0: BLUSBUIRT
3.0.0.45: Kinect
3.0.1.87: Z-Wave
