Alexa "CRITICAL: Plugin has disconnected."
    Has anyone had this message "CRITICAL: Plugin has disconnected.". Alexa interface works fine but I can't access the plugin settings. I've tried restarting the plugin and deleting it and reloading it.
    Also have this message flash for 5 seconds:
      have you installed the prerequisites as explained in the user guide?
      - disable the plugin
      - in Task Manager make sure there is no HSPI_Alexa.exe still running
      - edit Config/Alexa.ini and add the following lines:
      [GENERAL]
      log_level=Trace
      - enable the plugin again
      then post what you get in the logs
      Note: you don't need this plugin to control Homeseer devices using Alexa. This plugin is used to turn a windows PC with a microphone and speakers into an Alexa enabled device.
