Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > stefxx Plug-Ins
stefxx Plug-Ins Plug-Ins by stefxx
Closed Thread
Old April 21st, 2018, 03:47 AM
stefxx's Avatar
stefxx stefxx is offline
P1 Dutch Smart Meter
DESCRIPTION
Plug-in for the Smart Meters that are currently being installed all over The Netherlands (and possibly other European countries?) Requires a special Serial or USB to P1 (RJ11) cable.
REQUIREMENTS
  • This plugin is for HS3 or HS3PRO. It works with both Windows and Linux versions
  • .NET Framework 4.5 or later, or mono 4.x needs to be installed on your Homeseer machine
  • equires a special Serial or USB to P1 (RJ11) cable. See table below for the correct cable layout.
    Or just search the Internet for a P1 interface cable. It should look similar to this:
INSTALLATION
There are no additional software requirements. The plug-in can be installed from the HS3 updater, and can be found under the section “Energy Management”.
CONFIGURATION
After installation and starting the plug-in, go to the configuration page. They are five tabs:
  • Port Settings: Make sure the settings match the Smart Meter installed.
  • General: Set the update frequency (1 minute is usually fine) and if you want the daily totals to reset at midnight.
  • Energy: Settings to configure the HS3 build-in energy graphic
  • Debug: Enable advanced logging, normally disabled
  • Support: How to get support and how to donate
TROUBLESHOOTING
There is not much troubleshooting. If things don't work, you either have the wrong cable, or the wrong port settings.
stefxx
Old April 27th, 2018, 11:22 AM
stefxx's Avatar
Release notes
Version 3.0.0.12, 06-01-2018
- Fix: USB disconnect/reconnect
- Fix: high CPU utilization
Version 3.0.0.11, 09-11-2017
- Support for DSMR 5.x Smart Meters
Version 3.0.0.10, 04-01-2017
Support for newer Smart Meters (that support a checksum in the transmission)
Version 3.0.0.9, 29-12-2016
- Moved COM port selection to plugin config (workaround bugzilla #2224)
- Less frequent device updates (from every 10 second to a configurable 1-60 minutes)
- Update devices/energy only after HS3 has been fully initialized (avoids startup errors in log as well)
Version 3.0.0.8, 02-01-2015
- New: Support gas reading 0-2:24.3.0
Version 3.0.0.7, 08-12-2014
- Linux compatibility
Version 3.0.0.6, 10-10-2014
- Initial version in the Homeseer updater
- Fix: Startup crash when upgrading from previous version
Version 3.0.0.5, 16-09-2014
- New: Support for Energy graphs (requires Homeseer 3.0.0.126 or higher)
- Improved: Stability
Version 3.0.0.4, 06-04-2014
- New: If no data is received for 60 seconds, port will be reopened
Version 3.0.0.3, 26-02-2014
- New: Ability to adjust all comport settings to support different smart meter models
- New: Support gas reading 0-1:24.2.1
- Improved: COM port handling
Version 3.0.0.2, 23-02-2014
- Test version, for newer smart meters
Version 3.0.0.1, 04-02-2014
- Supports all common electricity and gas readings
- Min and max values on a daily basis
- Total usage on a daily basis
Closed Thread
HTML code is On
Neato Botvac Robot Vacuums stefxx stefxx Plug-Ins 2 May 10th, 2018 05:20 AM
Release Notes sooty PHLocation Plug-in (3P) 85 October 25th, 2017 06:18 PM
How well do self cleaning robot vacuums actually work? NeverDie Off Topic 57 December 29th, 2016 02:06 AM
Release Notes NicolaiL izKNX Plug-In 0 November 15th, 2016 06:20 PM
Release Notes NicolaiL izHeatmiser Plug-In 0 November 18th, 2014 06:23 PM
