Originally posted by rjh
View Post
Is the only setting still "gServerAddressBind"? Does this now point HSSentry as well as the web server to that IP address? The reason I ask, is that HSSEntry is still causing HS to continually restart when there are 2 adapters.
EDIT: Nevermind. I found it in the help file:
HSSentry
Enables a small monitoring program the monitors the built in web server. If the server does not respond, the system is restarted. This program is started when HomeSeer is started and it sends a small request to the HomeSeer webserver. If the server does not respond it will terminate the HomeSeer exe and then restart it. On Linux, it will restart the computer HomeSeer is running. The Sentry program gets the IP address of HomeSeer using the IP of the system it is running on. In the case where the system may have multiple IP addresses the IP address may be manually set by editing the settings.ini file in the HomeSeer Config folder. In the "Settings" section add line like:
SentryIP=IPADDRESS
The port number is obtained from the same settings file and is the port number that is set in the HomeSeer settings.
The number of errors that the sentry will allow before restarting is set with the setting:
SentryErrorCount=#
The default error count is 7.
The frequency of how often it checks the web server is set in the setting:
SentryCheckInterval=SECONDS
The default is 20 seconds.
