error when installing plugin
    I've tried the beta (3.0.3.14) followed by the release (3.0.2.0) version from the updater and get the same error.
    I'm installing on a hometroller S6 running Microsoft Windows Embedded Standard - Work Station
    Warning, Cannot load EXE file (possibly missing dependencies) HSPI_MeiHarmonyHub.exe: Unable to load one or more of the requested types. Retrieve the LoaderExceptions property for more information.Warning, Error details with EXE HSPI_MeiHarmonyHub.exe: Could not load type 'System.Runtime.CompilerServices.IAsyncStateMachine' from assembly 'mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'.Warning, Error details with EXE HSPI_MeiHarmonyHub.exe: Could not load type 'System.Runtime.CompilerServices.IAsyncStateMachine' from assembly 'mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'.Warning, Error details with EXE HSPI_MeiHarmonyHub.exe: Could not load type 'System.Runtime.CompilerServices.IAsyncStateMachine' from assembly 'mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'.Warning, Error details with EXE HSPI_MeiHarmonyHub.exe: Could not load type 'System.Runtime.CompilerServices.IAsyncStateMachine' from assembly 'mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'.Warning, Error details with EXE HSPI_MeiHarmonyHub.exe: Could not load type 'System.Runtime.CompilerServices.IAsyncStateMachine' from assembly 'mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'.Warning, Error details with EXE HSPI_MeiHarmonyHub.exe: Could not load type 'System.Runtime.CompilerServices.IAsyncStateMachine' from assembly 'mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'.Warning, Error details with EXE HSPI_MeiHarmonyHub.exe: Could not load type 'System.Runtime.CompilerServices.IAsyncStateMachine' from assembly 'mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'.Warning, Error details with EXE HSPI_MeiHarmonyHub.exe: Could not load type 'System.Runtime.CompilerServices.IAsyncStateMachine' from assembly 'mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'.Warning, Error details with EXE HSPI_MeiHarmonyHub.exe: Could not load type 'System.Runtime.CompilerServices.IAsyncStateMachine' from assembly 'mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'.Warning, Error details with EXE HSPI_MeiHarmonyHub.exe: Could not load type 'System.Runtime.CompilerServices.IAsyncStateMachine' from assembly 'mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'.Warning, Error details with EXE HSPI_MeiHarmonyHub.exe: Could not load type 'System.Runtime.CompilerServices.IAsyncStateMachine' from assembly 'mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'.Warning, Error details with EXE HSPI_MeiHarmonyHub.exe: Could not load type 'System.Runtime.CompilerServices.IAsyncStateMachine' from assembly 'mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'.Warning, Error details with EXE HSPI_MeiHarmonyHub.exe: Could not load type 'System.Runtime.CompilerServices.IAsyncStateMachine' from assembly 'mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'.Warning, Error details with EXE HSPI_MeiHarmonyHub.exe: Could not load type 'System.Runtime.CompilerServices.IAsyncStateMachine' from assembly 'mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'.Warning, Error details with EXE HSPI_MeiHarmonyHub.exe: Could not load type 'System.Runtime.CompilerServices.IAsyncStateMachine' from assembly 'mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'.Warning, Error details with EXE HSPI_MeiHarmonyHub.exe: Could not load type 'System.Runtime.CompilerServices.IAsyncStateMachine' from assembly 'mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'.Warning, Error details with EXE HSPI_MeiHarmonyHub.exe: Could not load type 'System.Runtime.CompilerServices.IAsyncStateMachine' from assembly 'mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'.
    HS4 Pro on Shuttle NC10U, Win10; Z-NET
    Number of Devices: 1005
    Number of Events: 293
    Plug-Ins: BLLock, DirecTv, EasyTrigger, Honeywell WiFi Thermostat, Marquis monoprice Amp, MeiHarmonyHub, PHLocation2, Pushover 3P, UltraM1G3, rnbWeather, Worx Landroid, Z-Wave
    External applications: Homebridge-homeseer, Geofency, EgiGeoZone.
    I'll have to check what windows has installed. My guess is that you might not have the version of .Net the plugin requires (4.6.2 I think). Can you check what version of .net you have installed on your system?
    I can try and lower the requirement to 4.5 which seems to be more popular, but from what I'm seeing in those messages it would mean a huge rewrite of the plugin.
      Thanks for getting back to me. .Net which was 4.0.30319. Updating .Net to 4.7.2 fixed the problem.
        I"m glad that fixed the issue for you
