Has anybody use door/window sensors to prevent hvac system from turning on when a door or window is open. did a search but did not come up with anything.
Ds10a
Originally posted by Rupp View PostI haven't done this but that's an excellent idea. It shouldn't be too hard to add a condition that would send an AC off if the DS10A is on/alert.
I chose this route because I wanted to know if the window was open for a variety of reasons, not just because the air conditioning was ON.
Also, I do not have DS10 sensors on all the windows; only the ones that are likely to get rain and those that are at ground level and pose a security risk.
Also I do not have a good way to turn off my central air via x10. I am currently investigating using the circuit for the "overflow safety switch" on the condensate pump, as a way to shut off the central air.
Knowing if the air conditioner is ON is also important. I am able to do this with a temperature sensor afixed to the main plenum of the furnace. Homeseer then compares the plenum temperature with the room temperature. If the plenum temp is 3-4 degrees lower than room temperature, It knows the air conditioner is ON. I then use a counter to count how often this occurs. This also tells me how many times the air conditioner runs each day.
Lots of possibilities!
Steve QHomeSeer Version: HS3 Pro Edition 3.0.0.368, Operating System: Microsoft Windows 10 - Home, Number of Devices: 373, Number of Events: 666, Enabled Plug-Ins
