Morning,
I have a motion sensor. I trigger things to turn on when it goes on, then when it goes off I setup a wait for x time, 120 minutes, when it goes on I also cancel the wait event. However it has stopped working for some reason. This used to work just fine and about 2-3 weeks ago it stopped, now it seems to end up turning off the lights and disabling things, despite the event being canceled. Is this a known issue?
BTW what homeseer is doing is hard to track in the logs since it doesn't log which event made a device change to occur... In the logs below the only place in the events the heater is switched to off, is in the event it theoretically canceled a minute before hand.
Here are the logs:
3/12/2013 10:04:18 PM Insteon ..Finished Scheduled Polling for 0 devices.
3/12/2013 10:04:20 PM Insteon Received message from Media Room Moton Sensor (21.D2.8E) taking hops: 1
3/12/2013 10:04:20 PM Insteon Received ]52 (Media Room Moton Sensor - Occupancy Sensor) Go ON
3/12/2013 10:04:20 PM Event Event Trigger "Downstairs Motion"
3/12/2013 10:04:20 PM Event Event No Occupancy downstairs cancelled by request
3/12/2013 10:04:20 PM Device Control Device: Down Media Room Heater (Q3) ON
3/12/2013 10:04:21 PM Insteon Received message from Media Room Moton Sensor (21.D2.8E) taking hops: 1
3/12/2013 10:04:33 PM Insteon Starting Scheduled Polling...
3/12/2013 10:04:33 PM Insteon ..Finished Scheduled Polling for 0 devices.
3/12/2013 10:04:35 PM Device Control Device: Down Media Room Heater (Q3) OFF
3/12/2013 10:04:35 PM Event Event Trigger "Unoccupied Downstairs"
3/12/2013 10:04:35 PM Event Sending infrared command: [DAIKIN HEATER]Daikin_heater,Off_fixed
3/12/2013 10:04:35 PM Device Control Device: Down Downstairs Group Off (\8) Value set to 1
3/12/2013 10:04:35 PM Insteon TransmitGroupMsg called for device code: \8, RF PLM Group 25
3/12/2013 10:04:36 PM Insteon Received message from Downstairs Cupboard Main (17.F2.9E) taking hops: 2
3/12/2013 10:04:36 PM Insteon Received message from Media Room Back section (1E.02.2E) taking hops: 2
3/12/2013 10:04:36 PM Insteon Received message from Media Room Floursecent Middle (1E.04
Here are the logs:
