I'm building some HS Touch screens for my Elk Panel and just added a bunch of simple text boxes and status tracking icons for Elk system error states. All buttons are set to Ignore presses and use custom status images for 0 and 1. I have plenty of other status objects for zones with the same images set up just the same with no issues.
However now my Android (144) client crashes on page load.
If I remove the setting for using custom graphic status images it's fine. I'm using exactly the same images (two simple png files) and paths as I do on another page with no issues. In fact I have 48 images for devices set up that work perfectly like this. When status = x show image a, when it's 1, show image b.
But I try and use these same images for status on these new items HS Touch crashes. The Windows client works perfectly.
I can go into each device in HS itself and change the default graphics, then remove my custom status rules and they show up ok, but when I do this and then update the Elk Plugin it resets all my graphics which really (&*@&* me off.
Any ideas? I need to find a way to post images to this post, but hopefully the explanation above is enough.
Current Date/Time: 3/26/2017 9:50:51 AM
HomeSeer Version: HS3 Standard Edition 3.0.0.313
Operating System: Microsoft Windows 8.1 Pro - Work Station
System Uptime: 2 Days 1 Hour 43 Minutes 20 Seconds
IP Address: 192.168.1.224
Number of Devices: 541
Number of Events: 35
Available Threads: 400
Enabled Plug-Ins
3.0.0.68: HSTouch Server
3.0.0.37: ISYInsteon
1.0.0.5: Restart
3.1.0.18: Sonos
3.0.6267.36391: UltraM1G3
3.0.0.63: weatherXML
Enabled Plug-Ins
1.0.0.5: Restart
3.1.0.18: Sonos
