If I enter a local lan address in the tasker device, it works perfectly. If I delete the local lan address, the plugin still tries to use the local lan address.
I am using the "flash 1 time" function in the control page. I have deleted the local lan from the tasker device. plugin debug is "on".
When I click on the "flash 1 time(or any command)" in the control, I get the following log entry in the tasker_debug_log.
7/13/2016 10:29:38 AM - DEBUG: Tasker SetIOMulti set value: 13->ref:22
7/13/2016 10:29:38 AM - INFO: Plug-In Extra Data Object Retrieved = SFNFTkMyL0FaYmVjNUhlUEl5M1lTaWFNMWNQMm5CbVRKWHhYQitReDZUT011 TmJLdFRFME9WOXJDczBXNFhNaEZnZ0dzR2MrelRJTFlPNUNFbzduSDc3NGpM SjByeHZSc1JMQ0Jab25uSkhRQklGb281R1hpRy95NXBFNzhJNk9vaUw4TlEv ZGlqakJVdmU2dHVROHBjZ3FaWlBtcHdoKzVFaWNjWVY3d1BKcGZxYXBvUU9E Y2l2bkdZSU9acVNzc20vRWdYdVpKZGxWeVJRVFoxVStTL0VKTEVrVVVUVXBU YUk5bndEZCt2dkc5RWsrVT0=
7/13/2016 10:29:38 AM - INFO: API = SFNFTkMyL0FaYmVjNUhlUEl5M1lTaWFNMWNQMm5CbVRKWHhYQitReDZUT011 TmJLdFRFME9WOXJDczBXNFhNaEZnZ0dzR2MrelRJTFlPNUNFbzduSDc3NGpM SjByeHZSc1JMQ0Jab25uSkhRQklGb281R1hpRy95NXBFNzhJNk9vaUw4TlEv ZGlqakJVdmU2dHVROHBjZ3FaWlBtcHdoKzVFaWNjWVY3d1BKcGZxYXBvUU9E Y2l2bkdZSU9acVNzc20vRWdYdVpKZGxWeVJRVFoxVStTL0VKTEVrVVVUVXBU YUk5bndEZCt2dkc5RWsrVT0=
7/13/2016 10:29:38 AM - DEBUG: Control String:
7/13/2016 10:29:38 AM - DEBUG: Control Value:13
7/13/2016 10:29:38 AM - DEBUG: Control Location:HomeSeerAPI.Enums+CAPIControlLocation
7/13/2016 10:29:38 AM - DEBUG: Control Device Value:13
7/13/2016 10:29:38 AM - DEBUG: System.UriFormatException: Invalid URI: The hostname could not be parsed.
at System.Uri.CreateThis(String uri, Boolean dontEscape, UriKind uriKind)
at System.Uri..ctor(String uriString)
at System.Net.WebRequest.Create(String requestUriString)
at HSPI_TASKER.Tasker.GrabUrl(String sURL, String UserAgent, Int32 Timeout)
7/13/2016 10:29:38 AM - ERROR: Sending local command failed: ()
7/13/2016 10:29:38 AM - ERROR: ----------------------------------------------------------------------
7/13/2016 10:29:38 AM - ERROR: Connection Error
7/13/2016 10:29:38 AM - DEBUG: Trying cloud connection instead!
7/13/2016 10:29:38 AM - DEBUG: Cloud Connection Status: OK
I would think that the plugin should check for a blank local ip address, and if found to be blank, not try to use the local lan connection.
