First up I thought I'd try Ubuntu to run the system with and change from aeon labs stick to zwave.me
What a total pain in the arse decision I've made.
The raspberry pi was running sweet as a nut. The reason I changed was hoping HS touch maybe a bit more responsive.
However after a catalogue of issues the one that is now hitting me is with Fibaro double relay.
I'm using S1 to turn on kitchen lights directly that's all good.
S2 is wired to the 2nd pole of a switch, this runs an event to control a device. Again all good and works now after re-installing the zwave plugin.
The issue is though S1 also triggers the same event as S2.
I don't know how to stop it. This didn't happen in the raspberry pi setup.
It's as if S1 has associated itself with S2 ???
