Fibaro Single Switch 2 reporting invalid binary frame
    So I havve tried to include the new Fibaro Single Switch 2 (FGs-213) with the Z-wave plugin version 3.0.1.87 and BETA 3.0.1.94
    When using the BETA I received the following: (basically could not add the device)
    sep-13 21:16:44 Z-Wave Warning Failed to get a SECURITY SCHEME or verify the key from node 35. Device may not be added properly to HomeSeer.
    sep-13 21:16:44 Z-Wave Error Z-Wave was unable to negotiate a compatible security scheme with node 35
    When using Z-wave plugin version 3.0.1.87, I managed to add the device but the homeseer log sends a warning whenever I switch the lights on or off with the switch:
    sep-13 21:29:20 Z-Wave Warning Probable Invalid (BINARY) Frame Received from Node 39 = 25-03
    Any idea what could be causing this? Is there a workaround?
    I am using an Aotec Z-wave usb stick. Would a new generation of this usb stick be a solution (as it has zwave plus support) ?
    Try adding the device as non-secure.
    Nicolai L
      I am having the same issue with 3.0.1.139, which according to the changelog should have fixed this issue:
      " Changed in version 3.0.1.139 (Beta)
      * Fixed Fibaro FGS-223 switches attached to S1/S2 now update status in HS ok
      However, the issue remains:
      09:49:27:6740:[Z-Wave Warning]->Probable Invalid (BINARY) Frame Received from Node 11 = 25-03
      ApplicationCommandHandler from node 11 HANDLING: COMMAND_CLASS_SECURITY Frame(7)=129
      This is frustrating, as the switch now shows ' INVALID VALUE', and scripts checking for ON or OFF no longer work.
        Removing the node and readding it in non-secure mode does seem to work. It remains weird though, this switch has always worked and it seems it suddently stopped working.
          I have the same issue. Non-secure mode seems indeed to work but I don't like to work un-secure. I don't like to remove/add about 15 Fibaro switch modules and modify all my related events.... I run 3.0.1.148 (Beta)now.
              This has been reported in different posts and with different zwave devices.
              Please can anyone of HS respond to these issues or do we have to file a bug report ?
              What's the difference between adding secure and non-secure anyway ?
              Rien du Pre
              The Netherlands
              Using:
              Plugin's:
              RFXCOM, mcsMQTT, Z-Wave
