can you post the log snippet surrounding the error in context
Lost all Insteon devices
Mark
HS3 Pro 4.2.19.5
the error in the log isn't related to your device being deleted and recreated.
do the devices get recreated every time you restart the plugin or hs?Mark
HS3 Pro 4.2.19.5
Originally posted by blueline View PostIt happens when the machine is rebooted. I tested disabling/enabling the Insteon plug-in, and it does not happen in that case.Mark
HS3 Pro 4.2.19.5
the insteon.ini is going to get updated even during startup (lastcontact gets updated). But nothing should be deleted from the file. Did the "create device" log entries occur after this reboot?Mark
HS3 Pro 4.2.19.5
Originally posted by blueline View PostI deleted the log file, and it didn't write out a new one. I created an empty logfile, but it still doesn't write to it. I also downgraded to 3.0.5.20, and the event issue still happens. I'm tempted to uninstall and reinstall HS3, but I'm not sure whether that will solve the problem.Mark
HS3 Pro 4.2.19.5
Originally posted by blueline View PostI started with a blank Homeseer database and existing insteon.ini. I had to rebuild all of the events from scratch, but the ids are no longer being changed. Hopefully, it won't happen again. Thanks for your help.Mark
HS3 Pro 4.2.19.5
I just went thru a recovery after several power fails. Restoring the homeseer Db and the corresponding insteon.ini worked just fine. I backup after every config change and it payed off big time.
Mark, this was recoverable but certainly not the behavior we want.
You mentioned in the other thread that HS3 managed the insteon.ini file. Why is that?
I was happy that the HS3 backup did seem to grab all the plugin config files so I had a complete point in time backup. But that really only needs them to know the name of your file and the ability to create a copy.
My experience is that file corruption after unexpected system restart is commonly due to handles being open with write access and not flushing buffers on every write. In the old days, we would close the handle after a write on critical data. Had to balance that with performance and data integrity. These days, don't need to worry so much about that but still a consideration. In my recent failure situation, nothing had been changed (in terms of configuration) in either HS3 or your plugin since I last backed it up (3 days ago). So who left the files in a state that would allow corruption. If you aren't writing to your .ini file in the course of normal operations, it would not seem to be you. If you aren't in control of the .ini, then whoever is should be managing it in a responsible manner.
In this day and age, system restarts should be safe. But.. it is up to the app designers to take that into consideration.
I bet you have thoughts on this and I'd really like to hear them.
Originally posted by logbuilder View PostI just went thru a recovery after several power fails. Restoring the homeseer Db and the corresponding insteon.ini worked just fine. I backup after every config change and it payed off big time.
I bet you have thoughts on this and I'd really like to hear them.Mark
HS3 Pro 4.2.19.5
I think there is potentially a twofold problem...
First, for the record, I am using 3.0.6.0 of the plugin and I don't see any redundant copies of the Insteon.ini file like described in this thread. Should they be in the same folder as Insteon.ini?
1. In my case, I will spontaneously find the situation where the Insteon.ini has basically been reset to default with no port defined and no devices. Consequently, all corresponding Insteon devices in homeseer have also vanished.
2. On occasion, I also see that the long and lat settings have been whacked back to the defaults for the timezone. I had previously manually set them to get proper sunrise/sunset times. Defined events and such remain.
3. On occasion, I find that all plugins become disabled. I also intermittently find errors on the manage page for plugins where insteon or zwave plugins will indicate it couldn't communicate with the device after startup...and yet a simple disable and enable of the plugins resolves the issue. I think that could be a timing issue where perhaps the homeseer startup is getting ahead of device init and perhaps the devices become available after plugins have attempted to be started. I have tried to find a way with scripting to disable and re-enable plugins but can't seem to figure out how. thinking at least I could have an event to trigger remotely...but sometimes hstouch shows disabled also. annoyed.
4. I notices that one or more of these problems appears after using the tools->system option to restart the system. How else can you ensure a clean shutdown and restart on a Pi3 headless system?
HS2 rocked and rolled so nicely for so many years. I am not so enchanted with HS3 with these issues. Granted, I'm now using a Pi3 instead of a PC...however these issues seem to be reported cross platform. I emailed homeseer support about two weeks ago about related issues and no response as of yet. I suppose I will have to make some time to call them during the week. For me this is unacceptable. I travel internationally at times and need for homeseer / insteon plugin / zwave plugins to do their job.
sorry for venting a little. just really frustrated.
Originally posted by martinl78 View PostI think there is potentially a twofold problem...
as for the backups of the insteon.ini file, please post #4 on the following thread
https://forums.homeseer.com/showthread.php?t=189540
you basically need to setup an event to make the backupsMark
HS3 Pro 4.2.19.5
