Mike, i get some duplicate devices sowing up after my mcs re-load. all my 13 zones show up correctly and then 7 zones just show up as Rain8 Unit and Valve numbers.... thoughts? can i delete those last devices?
HS devices duplication
set up zones
mike i have all my 13 zones on one area. runs the full program.
what if i also wanted to add two more programs by running 6 zones on another area and 7 on another. can i assign zones to two areas so i can program times for the different areas to run?HS3 , Zwave, HometrollerS6, ELK M1G Ultra; mcs sprinklers; WGL800; BLRF; BLNetCallerID; BLSpeech
Put 1,2, 3 in Area 1. 4,5, 6 in Area 2. Put the schedule you want for Area 1 and 2 which will specify the start time for zone 1 and 4. You can use same or overlapping times and mcsSprinklers will schedule in sequence.
For example if you want all 6 zones run at 8 AM, 1,2,3 at 1 PM and 4,5, 6 at 10 PM then define two programs for each Area 1 and 2. Area 1 will be at 8 AM and 1 PM. Area 2 will be at 8 AM and 10 PM. This will run all 6 zones in sequence starting at 8 AM and only 3 at each of the other two times.
