multiple kinects on remote system
    is it possible to run 2 kinects on one remote system?
    if so how do you set it up?
    yes it's possible
    start the first kinect instance by running the HSPI_Kinect.exe command line, go to the config page (General tab) for this instance and select one of the 2 "Kinect Sensor"
    then start the second kinect instance by running the HSPI_Kinect.exe command line with a different instance name parameter. then go to the config page (General tab) for this instance and select the other "Kinect Sensor"
      yes it's possible
      would it be possible to run 4? I found a USB card that has 4 separated USB buses.
      What would be the CPU recommendation and ram for something like this?
