Integrate Android Tasker with Homeseer (Old Thread)
      Hi Fischi, please try 3.0.0.10 if that fix your issue.
      Tasker Plugin / Speech Droid
      Tonlof | Sweden
        Thanks Tony
        Where to find/download 3.0.0.10. ?
        I found 3.0.0.9 only.
        Fischi
          Originally posted by Fischi View Post
          Hi Tony and Greig,
          Today I'm testing the communication Handy > Homeseer.
          I have added the following to the tonlof_tasker2hs.config :
          [Test]
          Droid.Speak=Schaltvorgang erfolgt
          HS.Event=Licht Flur ein
          I have created a task %HSCommand to Test
          After running the task I get the following entry in the HS3 log:
          <table class="log_table_row" cellspacing="0"><tbody><tr><td class="LogDateShort LogDateTime0" colspan="1" style=" white-space: nowrap;" align="left">Jan-02 10:41:03 </td><td class="LogPri0" colspan="1" align="left"> </td><td class="LogType0" colspan="3" align="left"> Tasker Plugin Error </td><td class="LogEntry0" colspan="8" align="left"> </td></tr> </tbody></table> <table class="log_table_row" cellspacing="0"><tbody><tr> <td class="LogDateShort LogDateTime1" colspan="1" style=" white-space: nowrap;" align="left"> Jan-02 10:41:03 </td><td class="LogPri1" colspan="1" align="left"> </td><td class="LogType1" colspan="3" align="left"> Tasker Plugin Error </td><td class="LogEntry1" colspan="8" align="left"> </td></tr></tbody></table>
          Where is the issue ?
          Regards, Fischi
          <table class="log_table_row" cellspacing="0"><tbody><tr><td class="LogDateShort LogDateTime1" colspan="1" style=" white-space: nowrap;" align="left">
          This is an error that Tony has fixed in the next version. I had the same problem.
          Try and set %HsRef to the word null in tasker as this may help but it depends on the version you are running.
          Im sure Tony will sort this for you soon.
          Greig.
          Scripts =
          Various
            sorry I was a little slow there.
            Greig.
            Scripts =
            Various
              Thanks Tony
              Fischi
              The updater_override.txt in the first post is for 3.0.0.10
              Greig.
              Scripts =
              Various
                Where is the download link for the plugin?
                  Hi, on the first post. http://board.homeseer.com/showthread.php?t=158888
                  Tonlof | Sweden
                    Hi Tony, hi Greig
                    It seems to run !!!
                    One question:
                    Is it possible in the config to add a HS:Wait ?
                    I want to HS.Event and 2seconds later HS.Droid to receive the correct
                    status value after the HS 3 event was running.
                    Best regards, Fischi
                      Hi Tony, hi Greig
                      It seems to run !!!
                      One question:
                      Great
                      Not possible in this version. I don't think it will happened in the tasker2hs call because it will may end up in timeout.
                      But what it may be possible is if you create an hs event that send the values when they changes.
                      Just a thought on how to solve it in future release.
                      [Sceene1]
                      hs.event=hseventname
                      hs.callbackdelay=2
                      hs.callbackreceiver=samsung,experiaz3
                      droid.speak=Event is triggered, waiting for data.
                      hs.callbackdata=speak|Hi, the value in device is now $$DSaddress)
                      Tonlof | Sweden
                        Hi Tony, hi Greig
                        It seems to run !!!
                        One question:
                        Try this. Use your HS event, do your things. At the bottom, add the delay and then send text to speech comand to tasker. You can use homeseer replacement variables in the data you send to tasker.
                        Tonlof | Sweden
                          Thanks, Tony,
                          I did it already the same way.
                          Is it also possible to set the volume of the handy for the HS.Droid messages ?
                          It's often impossible to do this with the handy's volume button .
                          The spoken words are often overmodulated.
                          Regards, Fischi
                            Okey, Tasker speech does not support volume settings.
                            Acapela have very nice voices that sounds great.
                            Tonlof | Sweden
                              Hi Tony,
                              How did you create the android screens shown at the previous page of
                              this thread ?
                              ( December 30th, 2014, 10:47 PM. #114 )
                              Regards, Fischi
                                Hi Tony,
                                this thread ?
                                Regards, Fischi
                                I am not sure what Tony used but I have been using Zoom
                                Greig.
                                Scripts =
                                Various
