There is an issue with the HS3 Updater in that when you update a plugin that you already have installed, the update will fail.
Here is what you can do to fix while the issue is resolved:
1. Disable the plugin you want to install
2. Make sure the EXE is not still running... if it is then kill the process
3. Go to the updater and install the plugin you want.
4. Enable the plugin
This should get you by until the issue is resolved.
