Originally posted by CJVann
View Post
ISY Insteon 3.0.0.54 - Beta 54 for HS3
Originally posted by bpwwer View PostNow that HS3 allows the status to be anything, I though I had removed the cases where the string was being set but I guess I missed some devices. On what type of device are you seeing the string field being used?
My "INSTEON IOLinc 2450 V3.6" devices (Garage Doors) are working okay! EVEN if I restart HomeSeer, it remembers that On=Closed & Off=Open, unlike the other devices.
Originally posted by bpwwer View PostI can certainly understand the desire to create custom status value pairs. So I'll give it some thought and see if there's some way to enable that. Early on there was a developer discussion that somewhat relates to this. Given that you can set the status to pretty much anything, how will script writers relate status values to anything meaningful? Do they have to do string matching for many different words that might mean the device is off (off, closed, deactivated, etc.)?
Status: "255=On"
Value: "255=Closed"
So just check to see if it's 255 or 0 to see if it's on-or-off, rather than the text-name associated with 255 and 0.
Just to be clear, I'm not trying to create a NEW custom set, but renaming the existing "Status" text-name of the standard "Value". For example:
0 = "Off" -> Change to "Open"
255= "On" -> Change to "Closed"
Some devices let you keep this new Open/Closed "Status" after a restart of HS3 (Like a INSTEON IOLinc 2450 V3.6), other devices (Like a Security V0.0(9)) delete the edited Closed/Open Values every time you restart HS3. It would be really nice if all devices let you keep the updated names, if that's possible.
Originally posted by CJVann View PostI agree, there's no way to check for every possible 'text' representation. Couldn't developers just check against the numeric "Value" rather than the text "Status"? For example, a device with a custom Status shows:
Status: "255=On"
Value: "255=Closed"
Even with the ISY, you can't assume that 255 means on because with the addition of z-wave support, z-wave devices report values 0 - 100 so 100 means on. The values reported by a device are device dependent values and it's the status that is supposed to normalize those somewhat.
I understand what it is you're trying to do and I'll see what I can do to make it work.
Thanks for all the input/feedback on this.
Originally posted by JB NY View PostCan I upgrade my ISY to 4.1.2 with this version of the plugin?
I've been noticing some very strange time stamps that are incorrect on a few devices (Motion & Door sensors). I now see that after a startup, the time stamps are being reset on these devices, and I found an error in the HS3 Log at the exact same time the devices are being reset. Could you take a look?
1/28/2014 5:31:15 PM ~!~Startup~!~ HomeSeer version 3.0.0.55 Edition: HS3 Standard Starting Now
Jan-28 5:31:35 PM ISYInsteon isyEvent : Parse failure: {0x3C}Event seqnum="2" sid="uuid:37"{0x3E3C}control{0x3E}_1{0x3C}/control{0x3E3C}action{0x3E}8{0x3C}/action{0x3E3C}node{0x3E3C}/node{0x3E3C}eventInfo{0x3E}C5DE5C.8CE6F7{0x3C}/eventInfo{0x3E3C}/Event{0x3E00}
From the HS3 Device Status Page:
Garage Door 1 Sensor INSTEON IOLinc 2450 V3.6 Today 5:31:35 PM
Garage Door 2 Sensor INSTEON IOLinc 2450 V3.6 Today 5:31:35 PM
Porch Motion-Sensor Motion Sensor US 915 MHZ 2842 222 V0 0 Today 5:31:35 PM
Mailbox Door Security V0.0(9) Today 5:31:35 PM
FYI: I have some "TriggerLinc 2421 V0.0" Door devices, but those are NOT being reset:
Barn Door TriggerLinc 2421 V0.0 1/22/2014 2:25:28 PM
Aquariam Lid TriggerLinc 2421 V0.0 1/25/2014 3:50:00 AM
Originally posted by CJVann View PostI've been noticing some very strange time stamps that are incorrect on a few devices (Motion & Door sensors). I now see that after a startup, the time stamps are being reset on these devices, and I found an error in the HS3 Log at the exact same time the devices are being reset. Could you take a look?
The plug-in will update the HomeSeer record for those devices as it gets the current status of the devices from the ISY after it first connects. If this is different from what's currently stored for the device, the last update time is set since the HomeSeer device is being updated.
That being said, I'm not seeing my IOLinc or Motion sensor devices change when I start HomeSeer.
Does this happen every time for these specific devices? If so, what's the status/value of the device before you shutdown HomeSeer and what is after the plug-in starts and updates the device time stamp?
Originally posted by bpwwer View PostDoes this happen every time for these specific devices? If so, what's the status/value of the device before you shutdown HomeSeer and what is after the plug-in starts and updates the device time stamp?
Just in case you needed to see the actual value/status/string, I did one more restart and captured that data (No change).
FYI, I think you have 100 as ON for the "INSTEON IOLinc 2450 V3.6" (Garage Doors 1 & 2) instead of 255. Awhile back I had added a Status of 0=Open, and 255=Closed. The 0 was overwritten by the plugin (Changed to 0=Off), but the 255=Closed remains and there is also a 100=On that doesn't seem to be used.
I have 4-8 button insteon keypads in the house. I can trigger events based on pressing the keypads. For some reason this only works on 7 of the 8 buttons. The 8th button which are my all off's can't trigger anything in homeseer. I have tried diffrent ways of progarming them but nothing works. Any ideas.
Looking at my keypads again I realized that the 8th key doesn't function like the other 7. The first seven keys when pressed illuminates the key when turned on. The 8th key when pressed illuminates for a split second and then turns back off. I'm assuming this is because it's the all off key. I am still able to trigger events from this key in HS2 but not HS3.
Originally posted by freeon View PostLooking at my keypads again I realized that the 8th key doesn't function like the other 7. The first seven keys when pressed illuminates the key when turned on. The 8th key when pressed illuminates for a split second and then turns back off. I'm assuming this is because it's the all off key. I am still able to trigger events from this key in HS2 but not HS3.
If you turn on debug logging (from the configuration page) and press a button that works and then the 8th button and post or send me the log it would help as I don't have any keypads configured as 8 button keypads, mine are all 6 button.
