Is it possible to create my own virtual device in RFXCOM? I need to know the amount of rainfall in the last xx hours (e.g., last 24 or 48 hours) in order to decide whether or not to allow the sprinkler system to run. The readings from my OS PCR800 do not give that information, but they do give me the readings I would need to calculate it. Is it possible to create my own?
Create my own virtual device
Here's a script I use to maintain the last 7 days of rainfall from the RFXCom plugin. I run the script every night at 23:59. Device 525 is my RFXCom device for today's rainfall and the others are virtual devices that maintain the values for the previous days that I use to determine whether to enable/disable my sprinklers. You may be able to do something similar and add a virtual device that hast the total rain fall over the last few days.
Cheers
Al
Code:Sub Main(ByVal inputparms as String) dim sourceDevString as String dim sourceDevValue as Double '1243, 1244 'store current value & string sourceDevValue = hs.DeviceValueEx(1243) sourceDevString = hs.DeviceString(1243) hs.SetDeviceString ( 1244, sourceDevString, True ) hs.SetDeviceValueByRef( 1244, sourceDevValue, True) '1242, 1243 'store current value & string sourceDevValue = hs.DeviceValueEx(1242) sourceDevString = hs.DeviceString(1242) hs.SetDeviceString ( 1243, sourceDevString, True ) hs.SetDeviceValueByRef( 1243, sourceDevValue, True) '1241, 1242 'store current value & string sourceDevValue = hs.DeviceValueEx(1241) sourceDevString = hs.DeviceString(1241) hs.SetDeviceString ( 1242, sourceDevString, True ) hs.SetDeviceValueByRef( 1242, sourceDevValue, True) '1240, 1241 'store current value & string sourceDevValue = hs.DeviceValueEx(1240) sourceDevString = hs.DeviceString(1240) hs.SetDeviceString ( 1241, sourceDevString, True ) hs.SetDeviceValueByRef( 1241, sourceDevValue, True) '1239, 1240 'store current value & string sourceDevValue = hs.DeviceValueEx(1239) sourceDevString = hs.DeviceString(1239) hs.SetDeviceString ( 1240, sourceDevString, True ) hs.SetDeviceValueByRef( 1240, sourceDevValue, True) '1238, 1239 'store current value & string sourceDevValue = hs.DeviceValueEx(1238) sourceDevString = hs.DeviceString(1238) hs.SetDeviceString ( 1239, sourceDevString, True ) hs.SetDeviceValueByRef( 1239, sourceDevValue, True) ' 525, 1238 'store current value & string sourceDevValue = hs.DeviceValueEx(525) sourceDevString = hs.DeviceString(525) hs.SetDeviceString ( 1238, sourceDevString, True ) hs.SetDeviceValueByRef( 1238, sourceDevValue, True) end Sub
