When running the HSTV Import Data Event I get the following error in the log. Any ideas what is causing this?
11/17/2007 9:20:21 AM - Info - Event Trigger "HSTV Import Data"
11/17/2007 9:20:21 AM - Info - Running script statement immediately: &hs.Plugin("HSTV").dataInsert()
11/17/2007 9:20:21 AM - HSTV - Starting data cleanup and listings import.
11/17/2007 9:20:21 AM - HSTV - No records to delete.
11/17/2007 9:20:25 AM - HSTV - Finished checking data
11/17/2007 9:20:28 AM - HSTV - Finished data cleanup and listings import.
11/17/2007 9:20:28 AM - HSTV - Listings import took less than one minute.
11/17/2007 9:20:28 AM - HSTV - Starting creation of all events.
11/17/2007 9:20:28 AM - HSTV - Finished creating events.
11/17/2007 9:20:29 AM - HSTV - Building the VR Command strings
11/17/2007 9:20:29 AM - HSTV - Error VR Install: Object variable or With block variable not set.
11/17/2007 9:20:29 AM - HSTV - Starting clean up of old xml data files.
11/17/2007 9:20:29 AM - HSTV - Finished cleaning up old xml files.
11/17/2007 9:20:29 AM - HSTV - Starting clean up of HSTV events.
11/17/2007 9:20:29 AM - HSTV - Finished cleaning up old HSTV scheduled events.
11/17/2007 9:20:29 AM - HSTV - Trigger Expire Date: Object reference not set to an instance of an object.
11/17/2007 9:20:29 AM - HSTV - Finished import cleanup.
