Also, download and install 3.0.2 in the updater
There are no locks configured in the plug-in.
I installed and restarted the new Z-Wave Plug-In .199, and stopped and restarted BLLock. Same issue as before. I also noticed this entry in the log while BLLock started:
Feb-15 18:24:23 BLLock warning Lock model name cannot be determined by the plug-in so processing of the lock is disabled!
There were only two of these, but all five locks show up in the plug-in page. None show battery status or message, either.
OK load 3.0.2 and then do this:
1. Delete debug log
2. Shutdown plugin
3. edit hspi_BLLock.ini and change debugLevel=true
4. save INI file
5. Restart plugin
Once plugin has been started for a few minutes, turn off debug logging and then attach the BLLock-Detailed.log file zipped in the HS3 root folder
I see 5 locks loaded and I see it getting the model for each lock
I do see errors calling the JSON api calls in the ZWave plugin
Is your HS3 web server running on port 80?
Try 3.0.3 and see if it makes any difference
Repeat the steps above to get a brand new debug log
02/15/2018 06:38:55:373 PM : v3.0.2.0 - Send_Homeseer_JSON_Request(): port --> 80
02/15/2018 06:38:55:374 PM : v3.0.2.0 - Send_Homeseer_JSON_Request(): url --> http://localhost:80/JSON
02/15/2018 06:38:55:374 PM : v3.0.2.0 - Send_Homeseer_JSON_Request(): parm: request; value: pluginfunction
02/15/2018 06:38:55:375 PM : v3.0.2.0 - Send_Homeseer_JSON_Request(): parm: plugin; value: Z-Wave
02/15/2018 06:38:55:375 PM : v3.0.2.0 - Send_Homeseer_JSON_Request(): parm: function; value: ZwaveFunction
02/15/2018 06:38:55:375 PM : v3.0.2.0 - Send_Homeseer_JSON_Request(): parm: p1; value: networks
02/15/2018 06:38:55:375 PM : v3.0.2.0 - Send_Homeseer_JSON_Request(): parm: p2; value: null
02/15/2018 06:38:55:375 PM : v3.0.2.0 - Send_Homeseer_JSON_Request(): parameters set
02/15/2018 06:38:55:479 PM : v3.0.2.0 - Send_Homeseer_JSON_Request(): ERROR - Caught this web exception - Error: ConnectFailure (Connection refused)
