I went low budget and bought two Monoprice detectors; a garage door sensor and a multisensor.
Both seem to work fine except that neither report the battery level.
I've removed and re-included them, rescanned them while awake etc. but can't get the battery % from either.
The battery device is created when they're included, just no data.
Wondering if it's something to do with the command class battery but I don't know enough about that.
Any ideas?
Current Date/Time: 11/3/2017 10:54:26 AM
Operating System: Microsoft Windows 10 Pro - Work Station
System Uptime: 2 Days 16 Hours 5 Minutes 31 Seconds
IP Address: 192.168.0.103
Number of Devices: 120
Number of Events: 60
Available Threads: 400
Enabled Plug-Ins
1.0.3.0: BLShutdown
2.0.66.0: BLStat
0.0.0.34: Pushover 3P
3.0.1.130: Z-Wave
Below is the Node Information for the MultiSensor;
23 Full Name: Node 23 Z-Wave Vision Sec Notification Sensor Polling: Polling Disabled
Manufacturer:
Vision Security Type:
0x2021 ID:
0x2101 Listens:
No Version: 4.05 (ZDK 6.51.6) Firmware: 5.1 Hardware: 1 Neighbor Count:
14 Speed:
100Kbps
Neighbors: 1, 2, 11, 28, 33, 34, 35, 36, 37, 38, 41, 43, 44, 47
Last Working Route: 39 (9.6K) Set Route:
Uses Interface: Z-Net Interface (1) Basic Type: ROUTING SLAVE, Generic Type: SENSOR NOTIFICATION, Specific Type: NOTIFICATION SENSOR
Command Classes:
Supported: Zwaveplus Info, Version, Manufacturer Specific, Device Reset Locally, Association, Association Grp Info, Powerlevel, Battery(V 1), Notification(V 4), Sensor Multilevel(V 7), Configuration, Wake Up, Firmware Update Md, Security
Supported Secure: Version, Manufacturer Specific, Device Reset Locally, Association, Association Grp Info, Powerlevel, Battery(Ver 1), Notification(Ver 4), Sensor Multilevel(Ver 7), Configuration, Wake Up, Firmware Update Md
Child Device: Battery CC: Battery Polling: Polling Interval: 12h, 0m, 0s
Child Device: Home Security CC: Notification Ver: 4 Polling: Polling Disabled
Child Device: Temperature CC: Sensor Multilevel Ver: 7 Polling: Polling Disabled
Child Device: Luminance CC: Sensor Multilevel Ver: 7 Polling: Polling Disabled
Child Device: Relative Humidity CC: Sensor Multilevel Ver: 7 Polling: Polling Disabled
Any ideas?
Enabled Plug-Ins
1.0.3.0: BLShutdown
2.0.66.0: BLStat
3.0.1.130: Z-Wave
Manufacturer:
0x2021 ID:
0x2101 Listens:
14 Speed:
100Kbps
Command Classes:
