Real time log not available
    Log info
    Originally posted by Tomadoggy View Post
    Similar to .75, no matter what I try I am unable to install this update. Have tried the standard disable first, etc. but cannot install.
    Log shown
      Try this
      1. Disable the plugin
      2. Restart HS3
      3. Update the plugin
      4. Enable the plugin
      Cheers,
      Bob
        Worked...but
        Originally posted by Blade View Post
        Try this
        2. Restart HS3
        Thank you, this did allow me to install the updated plugin, and the fix worked to allow display of the real time log! However the HTML for this page has omitted the HS3 navigation elements, screen shot below for your reference.
          Yes that is how the page has always displayed
          Cheers,
          Bob
            Works for me
            Works for me, thanks for letting me know. Since I have your attention, would there be any way to take information from the log file and make it available to HSTouch? I would really like to have my security screen show recent door/lock events so I can quickly view who/what happened and when. Very willing to collaborate with you on testing and trial.
            Kind Regards,
              #21
              No promises but let me give it some thought
              Can u add a feature request on my web site for this please
              I do have quite a few feature requests that I still need to get to
              Cheers,
              Bob
                #22
                I am still getting the error on Linux .402:
                HTML Code:
                System.Web.Compilation.CompilationException
                error : Unhandled Exception:
                Description: Error compiling a resource required to service this request. Review your source file and modify it to fix this error.
                Details: error : Unhandled Exception:
                Error origin: Compiler
                Error source file: /BLLock_activity.aspx
                Exception stack trace:
                  at System.Web.Compilation.AssemblyBuilder.BuildAssembly (System.Web.VirtualPath virtualPath, System.CodeDom.Compiler.CompilerParameters options) <0x6c76b658 + 0x0089c> in <filename unknown>:0
                  at System.Web.Compilation.AssemblyBuilder.BuildAssembly (System.Web.VirtualPath virtualPath) <0x6c76b608 + 0x0001f> in <filename unknown>:0
                  at System.Web.Compilation.BuildManager.GenerateAssembly (System.Web.Compilation.AssemblyBuilder abuilder, System.Web.Compilation.BuildProviderGroup group, System.Web.VirtualPath vp, System.Boolean debug) <0x6c782580 + 0x007a3> in <filename unknown>:0
                  at System.Web.Compilation.BuildManager.BuildInner (System.Web.VirtualPath vp, System.Boolean debug) <0x6d007440 + 0x0043f> in <filename unknown>:0
                Version Information: 4.5.1 (master/9db20c4 Fri May 13 15:41:42 EDT 2016); ASP.NET Version: 4.0.30319.42000
                  #23
                  That is odd
                  I am running 402 on linux as well and it loads up fine for me
                  Show me the files in your [hs3 root]\html/bin folder
                  Cheers,
                  Bob
                    #24
                    That is odd
                    HTML Code:
                    total 11040
                    -rwxr-xr-x  1 homeseer root      77 Mar 26  2015 autostart_hs
                    drwxr-sr-x  9 homeseer root    4096 Jan 17 16:11 bin
                    -rwxr-xr-x  1 homeseer root     271 Mar 26  2015 change_password.sh
                    -rwxr-xr-x  1 homeseer root   35310 Aug 24  2015 check_passwd
                    drwxr-sr-x  3 homeseer root    4096 Jan  9 22:59 Config
                    drwxr-sr-x  2 homeseer root    4096 Jan 10 15:37 ConfigBackup
                    drwxr-sr-x  8 homeseer root    4096 Jan 26 19:28 Data
                    drwxr-sr-x  3 homeseer root    4096 Jan  6 13:59 Docs
                    -rwxr-xr-x  1 homeseer root     683 Mar 26  2015 factory.sh
                    -rwxr-xr-x  1 homeseer root      54 Mar 26  2015 go
                    drwxr-sr-x  2 homeseer root    4096 May 16  2016 Grammar
                    -rw-r--r--  1 root     root 1073152 Aug  1 12:39 HAI.Controller.dll
                    -rw-r--r--  1 homeseer root   76288 Jan 17 10:10 HomeSeerAPI.dll
                    -rwxr-xr-x  1 root     root   21504 Nov 17 08:35 HS3Sentry.exe
                    -rwxr-xr-x  1 root     root   37376 May 16  2016 HS3SentryLinux.exe
                    -rw-r--r--  1 homeseer root   44032 Mar 26  2015 HSCF.dll
                    -rw-r--r--  1 homeseer root   13312 Jan 17 10:10 HSConsole.exe
                    -rw-r--r--  1 homeseer root    1518 Jul 19  2017 HSConsole.exe.config
                    -rw-r--r--  1 root     root  802304 Jan 22 17:41 HSPI_BLLock.exe
                    -rw-r--r--  1 root     root     358 May 10  2015 HSPI_BLLock.exe.config
                    -rw-r--r--  1 root     root  221184 May 29  2015 HSPI_HSTOUCH.exe
                    -rw-r--r--  1 root     root  909824 Dec 10 01:08 HSPI_MyQ.exe
                    -rw-r--r--  1 root     root    4784 Dec 10 01:08 HSPI_MyQ.exe.config
                    -rw-r--r--  1 root     root  507904 Sep 26 08:49 HSPI_OMNI.exe
                    -rw-r--r--  1 root     root     355 Aug  1 12:54 HSPI_OMNI.exe.config
                    -rw-r--r--  1 root     root  249344 Dec  3 20:59 HSPI_SKWARE_DEVICE_HISTORY.exe
                    -rw-r--r--  1 root     root    1538 Aug 13 14:17 HSPI_SKWARE_DEVICE_HISTORY.exe.config
                    -rw-r--r--  1 root     root 3139584 Jan  4 18:38 HSPI_ZWave.exe
                    -rw-r--r--  1 root     root     357 Dec 18  2012 HSPI_ZWave.exe.config
                    drwxr-sr-x 15 homeseer root    4096 Jan 26 19:01 html
                    -rwxr-xr-x  1 homeseer root      36 Mar 26  2015 install.sh
                    -rwxr-xr-x  1 homeseer root     408 May 16  2016 led.sh
                    drwxr-sr-x  2 homeseer root    4096 Jan 26 19:07 Logs
                    -rwxr-xr-x  1 homeseer root  930816 Mar 26  2015 Mail.dll
                    drwxr-sr-x  2 homeseer root    4096 Jan  4 20:00 Media
                    drwxr-sr-x  2 homeseer root    4096 Jan 17 16:11 mochad
                    -rwxr-xr-x  1 root     root     606 Aug 24  2015 password_check.c
                    -rwxr-xr-x  1 homeseer root      22 Mar 26  2015 play_audio.sh
                    -rwxr-xr-x  1 homeseer root     488 Mar 26  2015 register_with_find.sh
                    -rwxr-xr-x  1 homeseer root     487 Sep 28 13:41 restart.sh
                    -rw-r--r--  1 root     root  126976 Dec 10  2012 RssToolkit.dll
                    -rwxr-xr-x  1 homeseer root      14 Mar 26  2015 run_command_raw.sh
                    -rwxr-xr-x  1 homeseer root      44 Nov  9 09:46 run_command.sh
                    -rwxr-xr-x  1 root     root 2852352 Jan 17 10:10 Scheduler.dll
                    -rw-r--r--  1 homeseer root    1594 Jan 17 10:10 Scheduler.dll.config
                    drwxr-sr-x  2 homeseer root    4096 Jan  4 20:00 scripts
                    -rwxr-xr-x  1 root     root    2509 Dec 16 12:39 server.pfx
                    -rwxr-xr-x  1 homeseer root     405 Mar 26  2015 shutdown_controller.sh
                    -rwxr-xr-x  1 homeseer root      31 Mar 26  2015 shutdown.sh
                    -rwxr-xr-x  1 homeseer root      38 Mar 26  2015 speak.sh
                    -rwxr-xr-x  1 homeseer root      32 Mar 26  2015 speak_to_file.sh
                    drwxr-sr-x  2 homeseer root    4096 Jan  4 20:00 temp
                    drwxr-sr-x  2 homeseer root    4096 Mar 26  2015 Temp
                    -rwxr-xr-x  1 homeseer root     195 Mar 26  2015 updatehs.sh
                    -rw-r--r--  1 root     root   56988 Jun 17  2016 updater.txt
                    drwxr-sr-x  3 root     root    4096 Jan 26 19:08 Updates3
                    -rwxr-xr-x  1 homeseer root     493 Mar 26  2015 update.sh
                    drwxr-sr-x  3 root     root    4096 Jan  4 21:35 usr
                    drwxr-sr-x  2 homeseer root    4096 Mar 26  2015 Wave
                    drwxr-sr-x  2 homeseer root    4096 May 16  2016 wave_files
                      #25
                      I need to see the html\bin folder
                      Cheers,
                      Bob
                        #26
                        Sorry, thought I was in html/bin
                        HTML Code:
                        Anthem.dll
                        CSScriptLibrary.dll
                        HomeSeerAPI.dll
                        HomeSeerUtil.dll
                        HSCF.dll
                        HSPI_BLLock.exe
                        Mail.dll
                        Mono.CSharp.dll
                        RssToolkit.dll
                        Scheduler.dll
                        sqlite3.dll
                        SQLite.Interop.dll
                        System.Data.SQLite.dll
                          #27
                          real time log error
                          I'm getting the same error with real time logs
                          I was using plugin version 3.0.8.0. I disabled it, restarted HS and upgraded to 3.0.11.0.
                          I know it has something to do with Mono since I'm getting same error using a number of Jon00's scripts, but HS isn't interested in helping me fix the issue.
                            #28
                            Hmmm I am getting this now in Linux as well
                            Mine was working fine before so it is not just you
                            Cheers,
                            Bob
                              #29
                              this thread is the top google result for BLLock real time statistics not working. this is on linux system with mono more recent than 5.0.1.1 or so. here's how to fix it:
                              sudo install -p /usr/bin/vbc /usr/bin/vbnc
                              thanks to MattL0 from https://github.com/mono/mono/issues/...ment-760592342
