Wim,
I thought I would make a separate thread as my issue continues. I have since got a couple of other ikea bulbs a GU10 white spectrum and an Ikea eu27 colour spectrum is addition to the E27 white spectrum.
All have been updated to the latest firmware level for the white spectrum that is 1.2.217 and for colour 1.3.002.
I have swapped the GU10 on both the DeConz and Hue hub. All the others are on the DeConz hub.
The event has controlled both an individual light and a group of lights; it is currently set to do a group
My observations are:
1.All lights can be controlled and work as expected from the device page
2.All lights can be controlled and work as expected from their zigbee controller: hue or DeConz
3.The colour spectrum works as expected from the set lights event
4.Both white spectrums do not work correctly from the set lights event when on either the hue or DeConz hub.
5. Transition to off over 5 seconds works correctly for all lights.
The issue I have is that from a lights set event I get variable behaviours. Currently from two events controlling the same light and set up the same behave as follows;
1. Event turns it on at the lowest setting and does not raise to full brightness despite the brightness being set to 254. The lowest setting is likely to also have been the last setting.
2. The other event turns it on at the brightest setting consistently.
3 Setting up a new event seems to always operate as per item 1. the event in 2. was set up some time ago.
I also have another event for the same light which is set to transition to full brightness over 5 seconds and it just turns on to the lowest Setting and remains there as 1. above.
Another light hue or Osram on the same event works correctly either turning on at full brightness or transitioning to full brightness.
Previous behaviours included starting at the lowest level before flashing full brightness and back to lowest level- I have not seen that recently.
I am on the latest DeConz 2.05.11 and JowiHue 2.02.00.
Steve
Steve
