I have a couple devices that I already have programmed into the plugin that I will be replacing with new ones...what is the best way to do this via the plugin, since the device addresses will change? Can I keep the same HS device code?
Best way to replace existing device
Near76Tags: None
Go into the plug-in INI file and change the address of the switch to the new address. Then just run HomeSeer and select the reprogram device option.
I will be adding an option to do this within the plug-in. I'm concerned however that people will think that all device to device links will be restored. This is not the case - only PLC to the replaced device links will be restored to the new switch.
Jon
Originally posted by Near76I have a couple devices that I already have programmed into the plugin that I will be replacing with new ones...what is the best way to do this via the plugin, since the device addresses will change? Can I keep the same HS device code?Jon Ort
JonOrt@The--Orts.com
