Just a quickie note here relating to the HS2 X10 CM11A plugin.
Its been broken since around 2005.
Subsequent revisions of said plugin have always been broken.
It is understood that HS2 is no longer being supported and that it was updated recently to version .81 fixing many issues with it.
That said this issue was never caught but could have been causing much grief for those folks wanting to continue to use X10.
You can see the "faults" here with the plugin by using Microsoft PortMon and watching the serial port communications to the CM11A.
They are timing out and can probably on the long term mess with your base Homeseer 2 setup.
This is the error you will see no matter how you connect to the CM11A (direct serial and or in a VM and or USB).
Here is a list of the HSPI_CM11A "broken" versions with attachments of all versions here to check for yourself.
HSPI_CM11A Version 1.0.1.0 Dated:08/15/2005
HSPI_CM11A Version 1.0.2.0 Dated:11/07/2005
HSPI_CM11A Version 2.2.0.4 Dated 06/29/2007
0.07897400 HomeSeer.exe IRP_MJ_READ EdgeSer26 TIMEOUT Length 0:
0.07890528 HomeSeer.exe IRP_MJ_READ EdgeSer26 TIMEOUT Length 0:
0.07783531 HomeSeer.exe IRP_MJ_READ EdgeSer26 TIMEOUT Length 0:
0.07881616 HomeSeer.exe IRP_MJ_READ EdgeSer26 TIMEOUT Length 0:
0.07785263 HomeSeer.exe IRP_MJ_READ EdgeSer26 TIMEOUT Length 0:
0.07884438 HomeSeer.exe IRP_MJ_READ EdgeSer26 TIMEOUT Length 0:
0.07685670 HomeSeer.exe IRP_MJ_READ EdgeSer26 TIMEOUT Length 0:
