all devices and events get lost
Very strange. It does sound like the config db is becoming corrupt somehow.
Sent from my SCH-R970X using TapatalkHS4Pro on a Raspberry Pi4
HSTouch Clients: 1 Android
Originally posted by Rupp View PostIs your database marked read only? Are there any errors in the HS3 log file when you start up or shut down HS3? What OS are you running HS3 on? Lastly, what version of HS3 are you running?
Please do not suggest going to Win 7 or 8, I would consider 10.While I have you attention X10 is extremely slow, like 5+ mins to react.sigpic
@Gordon, maybe trying Linux might work?
You only really see the Homeseer 3 GUI via the web when running in Linux.
You could even run it off a USB stick while leaving your current XP stuff in place.
Just sent an A1 (chime command) on the Linux HS3 box. It was instant (I heard the chime).
Jul-02 8:00:01 PM X10 DEBUG CM11A Sending: 4 66 Size: 2
Jul-02 8:00:01 PM X10 DEBUG CM11A Got checksum: 6A
Jul-02 8:00:01 PM X10 DEBUG CM11A Checksum OK, sending 0
Jul-02 8:00:01 PM X10 DEBUG CM11A Got ack of: 55
Jul-02 8:00:01 PM X10 DEBUG CM11A Sending: 6 63 Size: 2
Jul-02 8:00:01 PM X10 DEBUG CM11A Got checksum: 69
Jul-02 8:00:02 PM X10 DEBUG CM11A Got ack of: 55
Jul-02 8:00:06 PM X10 DEBUG CM11A Sending: 4 66 Size: 2
Jul-02 8:00:06 PM X10 DEBUG CM11A Got checksum: 6A
Jul-02 8:00:06 PM X10 DEBUG CM11A Checksum OK, sending 0
Jul-02 8:00:06 PM X10 DEBUG CM11A Got ack of: 55
Jul-02 8:00:06 PM X10 DEBUG CM11A Sending: 6 62 Size: 2
Jul-02 8:00:06 PM X10 DEBUG CM11A Got checksum: 68
Jul-02 8:00:07 PM X10 DEBUG CM11A Got ack of: 55- Pete
Originally posted by Gogs View PostHi Rupp, None of the databases are marked read only and I am running HS3 V 2.0.0.280 on XP Pro
7/2/2016 11:48:40 ~!~Database~!~Opening (Mode=Read Only) up HomeSeer database C:\Program Files (x86)\HomeSeer HS3\Data\HomeSeerData.hsd
7/2/2016 11:48:40 ~!~Warning~!~Configuration database has no devices in it: C:\Program Files (x86)\HomeSeer HS3\Data\HomeSeerData.hsd
How can I change the mode to read/write?
Originally posted by scheder@ga.com View PostInteresting, my log says the following:
Originally posted by Rupp View PostThis mode = Read only is normal during start up as it's only reading the database at this time. If you create a new HS config database are you still seeing this issue? Are there any journal files showing in your C:\Program Files (x86)\HomeSeer HS3\Data directory?
Unfortunately I now have to re-enter all of the information and hope that it doesn't corrupt again.
Regarding journal files, are those the files like HomeSeerData_#.hsd where # is a number? Yes, in my old corrupt database there were 10 of those journal files. Can they somehow be used to fix the database?
Also, you asked me to observe what happens during HS3 shutdown. I would expect that it writes out an error message when it's not able to save its database with the changed devices. Unfortunately I don't know how to observe the shutdown log. In the webinterface there are no updates under the "Log" link during shutdown. And trying to interpret the HomeSeerLog.hsd file in the "log" directory is very difficult. Is there a utility to interpret this file as it's a binary file?
Those HomeSeerData_#.hsd are auto backup files in case one of the files gets corrupted. I would first try backing up your database using the Tools > Setup > General Tab > Configuration section backup and then restore. You may want to try a restore into your new database and see if you can add new devices to that.
