Jon00 Homeseer/Echo Skill Helper for Homeseer 3 & Homeseer 4
    #31
    Yes it's a bug in the tag parsing. I'll get it corrected in the next version.
    Jon
      #32
      This looks fantastic!
      But one thing I have yet to understand. Is it possible to make Alexa read directly from Events (instead of using the HS speaker client which doesn't work for me at the moment)?
        #33
        You cannot send anything to Alexa without receiving a voice response first.
        Jon
          #34
          Just an idea. Could you spoof receiving a voice command, to be able to trigger Alexa to say something ?
            #35
            Smart suggestion. Would be awesome,!
            Verstuurd vanaf mijn Moto G (4) met Tapatalk
              #36
              Not sure its smart, more likely stupid and not doable. But if that was a way...
                #37
                Why? I like the idea. Using the echos for non echo related messages
                  #38
                  Just playing with this and it is working really well here. Thanks!
                  One question - I would like to pass commands back to Mainlobby/MLServer. I use the script immediate function such as
                  &nhs.PluginFunction("BLML2HS", "", "MLServeCmd", new Object(){"MLCAV66|SetVolume~1~5~0"})
                  Can an equivalent script be executed using the RunScript parameter in JOn00Alexa.ini?
                    #39
                    I would too. Hence me thinking of ways to do it. Just don't really understand enough about it to try and develop something
                      #40
                      This may work. Save the following script say TestVolume.vb and place in the scripts directory.
                      PHP Code:
                          Sub Main(ByVal Parm As String)
                      Dim MLS As String ""
                      For Each c As Char In Parm
                                  MLS
                      &= "~" c
                              Next
                              hs
                      .PluginFunction("BLML2HS""""MLServeCmd", New Object() {"MLCAV66|SetVolume" MLS ""})
                      End Sub
                      For the [Trigger] you are defining (say to set the volume) add Runscript=TestVolume.vb
                      If your Trigger word is volume (AlexaText=volume), you can say:
                      Alexa, tell Homeseer to set the volume to 120.
                      The number 120 is passed to the script parameter called Parm.
                      I have then added ~ characters as per your example which should convert that to ~1~2~0
                      That string is then included in the final Plugin command which should send 120 to MainLobby.
                      If the commands you want to send are not numeric and you just want to run different commands as a result of a trigger, you can use the ScriptParm entry of the script to define what is sent to Mainlobby i.e.
                      PHP Code:
                      Select Case Parm
                      Case Is "1"
                      hs.PluginFunction("BLML2HS""""MLServeCmd", New Object() {"MLCAV66|SetVolume~1~0~0"})
                                  Case
                      Is "2"
                      hs.PluginFunction("BLML2HS""""MLServeCmd", New Object() {"MLCAV66|SetVolume~1~2~0"})
                                  Case
                      Is "3"
                      hs.PluginFunction("BLML2HS""""MLServeCmd", New Object() {"MLCAV66|SetVolume~1~4~0"})
                      End Select
                          End Sub
                      If ScriptParm=1 then the line hs.PluginFunction("BLML2HS", "", "MLServeCmd", New Object() {"MLCAV66|SetVolume~1~0~0"}) would be executed.
                      If ScriptParm=2 then the line hs.PluginFunction("BLML2HS", "", "MLServeCmd", New Object() {"MLCAV66|SetVolume~1~2~0"}) would be executed.
                      Etc.
                      Jon
                        #41
                        I have been away for a few days. I received my dot today, installed that. Both Echo and dot are working fine with the api. Then I went on to test again with Crocy22's custom skill which I have been using to test the helper (I am still on 0.3b). That stopped working completely. So when I say anything Alexa tell the house...response I'm sorry that command was not recognised. Very strange. Anybody else experiencing these issues ?
                        I had a look in the log and cannot see anything Alexa related. So that's the issue. Maybe I should ask that question in the other thread, ops probably more custom skill related
                          #42
                          There was a DNS attack yesterday: http://board.homeseer.com/showthread.php?t=184606
                          Jon
                            #43
                            Originally posted by Simonk View Post
                            I've installed this and it seems to be working great.
                            Apart from devicetime which I'm using in the AlexaResponse
                            AlexaResponse=The temperature in the office [devicetime 255] minutes ago was [Devicevalue 255] degrees centigrade
                            When devicetime is in the AlexaResponse it fails to work with the error below
                            Oct-20 20:32:18 TTS Speak (json:
                            Oct-20 20:32:18 Info Heard: the office temperature
                            Oct-20 20:32:18 Jon00_Alexa Script processing time: 34 ms
                            Oct-20 20:32:18 Jon00_Alexa Response sent to Alexa: ''
                            Oct-20 20:32:18 Jon00_Alexa Successful trigger under [Trigger1]
                            Oct-20 20:32:18 Jon00_Alexa Error in tags function: (Conversion from string "255]" to type 'Integer' is not valid.)
                            Oct-20 20:32:18 Jon00_Alexa Integer Parsed: -9999
                            Oct-20 20:32:18 Jon00_Alexa Alexa Number String:
                            Oct-20 20:32:18 Jon00_Alexa Alexa command heard: 'office temperature'
                            Any ideas what might be causing this?
                            V1.0.1 is now available which corrects the devicetime tag issue.
                            Jon
                              #44
                              I think that was probably it. Its working again, although I had a few time outs, so there might still be small issues related to that DOS attack
                                #45
                                Does this work on the Raspberry PI version of HS3? I've just installed it but it didn't seem to take effect.
                                Just wanted to check before I spend any time looking into it.
                                Matt.
