Log filter restricts time to yesterday
Originally posted by Richel View PostNew issue that has not resolved with restarting HS3. I cannot set a date for filtering the log other than a time yesterday. Please see the photo.[ATTACH]61762[/ATTACH]
Any suggestions to correct problem would be appreciated. Thanks.
Elliott
Originally posted by integlikewhoa View PostIf there is no other dates in the log it means the log was purged. Maybe you have way to much logging going on and it filled up. Settings in the main hs3 settings for how big the log can get and how many days. It overwrites when it hits you max size. So I would open your log and see how much stuff you have in there and what your settings are set to.
Elliott"Living with technology means living in a [constant] state of flux." S. Higgenbotham, 2023
Originally posted by Richel View PostWell, that in fact may be the problem! Thanks. I have some energy meters that are generating a lot of data in the log. Do you know that if I do not log those meters, I can still graph the energy data?
Elliott
I don't think the logs have anything to do with graphing, but I'm not sure what your using for graphing. I use JON00's and it doesn't use the logs (I don't think anything else does either).
Also you can raise the size of your logs depending on which hardware your on shouldn't be much of an issue.
Originally posted by integlikewhoa View PostI don't think the logs have anything to do with graphing, but I'm not sure what your using for graphing. I use JON00's and it doesn't use the logs (I don't think anything else does either).
Mine is doing the same thing. But what's interesting is the only option is yesterday. Not today.
When in auto-update, it show current time going back about 2 hours. Then it jumps to previous day.
Log size is set to 50Mb. Surely it's not filling up 50Mb per day.
I'm on a Hometroller Zee S2. what size could it handle?
I also have a energy meter that is updating about every 3 seconds. How can I stop it from logging?
