Hi everyone -
I'm hoping someone here with more experience than myself may know how to do this. I have HS running with a 2414U PLC and about 10 Insteon devices controlling lights. I'm phasing out all my x-10 modules but still have a couple left.
I have one Remotelinc and two Controlinc units in my configuration as well as two access points.
I have registered my two Controlinc units to HS and they do show up along with the 5 buttons on each unit.
What I'm trying to find out is how I can use one of the buttons on the Controlincs to kick off a triggered event in HS to turn on certain house lights. This is a kind of way around the ALL ON button only controlling the lights directly linked to the Controlinc units. The event would bring on many of the lights in the house as a kind of panic mode ALL ON.
I see how to trigger such an event in HS using an X-10 command, but I can't seem to get HS to recognize key presses on the Controlincs in Insteon mode. I presume that's because they are controllers.
Right now the best I can come up with is using the Controlinc's ability to send an X-10 command which I can use to trigger an all on type event in HS. Unfortunately, I run into the usual limitations with X-10 such as not having the Controlincs on the same phase of the power, etc. I'd love to get away from any dependency on X-10 if I could.
Anyone have any bright (chuckle) ideas?
