According to the manual here:
http://digitalhomesystems.com.au/doc..._Sensor_v1.pdf, this Australian/NZ motion/illumination/temp sensor is supported by HomeSeer, but I can only get temp & luminosity readings.
Unfortunately the manual only covers the Vera setup.
Here are some screenshots of how I have it configured:
http://imgur.com/a/jrj3e
I've made sure the device is awake, by removing/adding batteries and optimised the node 4 times.
I've added & deleted the nodes with the button on the USB and via HomeSeer's management page.
I hold down the rocker switch on the sensor for about 5 seconds to add & configure.
HomeSeer version 2.5.0.49 &
I'm using it with the Aeon Labs USB stick:
Z-Wave Z-Wave interface1 version: 5
Z-Wave Controller Manufacturer: Aeon Labs, ID=0x1, Type=0x2
Z-Wave Controller firmware version: 3.7
Z-Wave This Z-Wave PC Controller Library Version is: ZDK Version 5.02 Patch 3
Z-Wave This Z-Wave PC Controller is Type: ZW_LIB_CONTROLLER_STATIC
Can anyone see what I've done wrong, or is this unit not supported? I have two of them so it's unlikely they're both faulty in just the motion detector bit.
Cheers
Cheers
