I have never seen this issue or really any issues with your plugins until today. Always rock solid. I recently got a new controller for a business install and when I shut down Homeseer I get an error. Aside from the error the devices will randomly disappear. If I disable the plugin and re-enable it all is well again. But being this is a customers unit that is an hour outside of town I'd like to figure out the root cause.
Thanks.
HomeSeer Model: HomeTroller S6
HomeSeer Version: HS3 Pro Edition 3.0.0.152 (Windows)
Plugin Version: 3.0.5308.30380
Plugin Error upon closing out HomeSeer:
HSPI_UltraGCIR3 has stopped working
Problem signature:
Problem Event Name: APPCRASH
Application Name: HSPI_ULTRAGCIR3.exe
Application Version: 3.0.5308.30380
Application Timestamp: 53c45129
Fault Module Name: clr.dll
Fault Module Version: 4.0.30319.1
Fault Module Timestamp: 4ba1d9ef
Exception Code: c0000005
Exception Offset: 0005f955
OS Version: 6.1.7601.2.1.0.320.65
Locale ID: 1033
Additional Information 1: 43cb
Additional Information 2: 43cbf21d8b1288de7fb82384112ab038
Additional Information 3: 9dc9
Additional Information 4: 9dc982345457ea46a91f32a8bf96776d
Read our privacy statement online:
http://go.microsoft.com/fwlink/?link...8&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
Install log:
Feb-10 2:49:57 PM Info Plugin UltraGCIR3 has connected. IP:127.0.0.1:49499
Feb-10 2:49:56 PM Plug-In Interface UltraGCIR3 is running as a trial, 30 days remaining.
Feb-10 2:49:36 PM Updater Install/Update of package UltraGCIR3 (Global Cache Network Adapter) was successful.
Feb-10 2:49:36 PM Updater Extraction Complete.
Feb-10 2:49:36 PM Updater Extracting files from zip file: C:\Program Files\HomeSeer HS3\Updates3\UltraGCIR3 (Global Cache Network Adapter)3.0.5308.30380\images.zip Destination: C:\Program Files\HomeSeer HS3\html\images\hspi_ultragcir3\
Feb-10 2:49:36 PM Updater Copying file: C:\Program Files\HomeSeer HS3\html\hspi_ultragcir3\UltraGCIR3_HSPI_Users_Guide.pdf
Feb-10 2:49:36 PM Updater Copying file: C:\Program Files\HomeSeer HS3\html\hspi_ultragcir3\Web.Config
Feb-10 2:49:36 PM Updater Copying file: C:\Program Files\HomeSeer HS3\html\hspi_ultragcir3\js\hspi_ultragcir3_ajax.js
Feb-10 2:49:36 PM Updater Making dir: C:\Program Files\HomeSeer HS3\html\hspi_ultragcir3\js\
Feb-10 2:49:36 PM Updater Copying file: C:\Program Files\HomeSeer HS3\html\hspi_ultragcir3\hspi_ultragcir3.aspx
Feb-10 2:49:36 PM Updater Copying file: C:\Program Files\HomeSeer HS3\bin\hspi_ultragcir3\System.Data.SQLite.dll
Feb-10 2:49:36 PM Updater Copying file: C:\Program Files\HomeSeer HS3\bin\hspi_ultragcir3\SQLite.Interop.dll
Feb-10 2:49:36 PM Updater Making dir: C:\Program Files\HomeSeer HS3\bin\hspi_ultragcir3\
Feb-10 2:49:36 PM Updater Copying file: C:\Program Files\HomeSeer HS3\hspi_ultragcir3.exe.config
Feb-10 2:49:36 PM Updater Copying file: C:\Program Files\HomeSeer HS3\HSPI_ULTRAGCIR3.exe
Feb-10 2:49:35 PM Updater Installing package UltraGCIR3 (Global Cache Network Adapter)
Feb-10 2:49:35 PM Updater Update HSPI_ULTRAGCIR3.exe downloaded successfully
Feb-10 2:49:33 PM Updater Downloading update: UltraGCIR3 (Global Cache Network Adapter)
Feb-10 2:49:33 PM Updater Starting download of updates
Thanks.
Problem signature:
Locale ID: 1033
Install log:
