1) Is there any difference in the way the EZFlora-HS3 plug-in handles the EZRain V1 vs the EZFlora - other than that the EZFlora has an additional sensor interface?
2) Are the EZRain V1 and EZFlora controllers useable sid-by-side with the EZFlora 2.0.0.1 plug-in with HS3? If "not", what are the issues that may or will arise?
3) Is it OK to directly edit the text labels in the ezflora.ini file? (This was done as a shortcut to configuring the text-name fields in meaningful ways.) Is there a character length restriction on these text fields?
4) The default for adding an EZFlora device seems to be that "debug" mode is "on", even though HomeSeer doesn't actually show this. Then, if the debug-off is clicked, program 4 and valve 8 icons show "on" which means that 4 & Valve 8 must be manually turned off. Then, the valves operated via manual control or events as expected. Is this normal behavior?
5) when deleting an EZFlora device, all features must be checked "on" or the device will not be removed. Is this normal behavior?
6) Smartenit will "attempt to upgrade" the firmware in an EZRain V1. What benefit is there in doing this?
