Hi Pete
You will recall that we had no luck with the Mono upgrade attempt recently using the JSON Import/Export function.
Since then, I have been wondering if the jump I made from 3.2.8 to 5.XXX was too big and that is why the import did not work. I was thinking of giving it another try but one step at a time, going from 3.2.8 to 4.XXX, and then using import. I saw one user mention he did not lose the triggers with this step. Anyway, I have been waiting for a new Transcend 32 GB SSD for my SEL to arrive and I was going to combine the Mono upgrade attempt with an Ubuntu 64 bit build for my SEL. I'll do the Zee S2 later. I'll let you know when I start the project Probably need your advice
That said, the second method you suggested using Windows HS3 looks intriguing. I might give this a try on my Zee S2 as it doesn't look time consuming. Knock on wood
Thanks for the advice.
