HS3 Beta Plug-In Available for Testing
    #61
    Originally posted by zefram View Post
    Yoyo,
    Please make it available in the store.
    I think enough people want to buy it.
    Robert (out of control)
    Yeah I know... I'll get in touch with the fellas at the store and get it done. I've posted a new build which will run for quite some time, but I want to get this done before the end of the month.
      #62
      Yoyo,
      Thank you!
        #63
        Yoyo,
        Thanks a lot.
          #64
          Originally posted by YoYo View Post
          Not sure what you're talking about... it uses whatever name you've typed in when learning.
          Perhaps the .rem file came over from a HS2 install? In that case you should run the utility discussed here to convert your HS2 installation. It will retrieve the names from HS2 and update the .rem file saving a bunch of work.
          Thank you. I found the problem.
          The plugin was connecting to the IRTrans server on my old HS2 system (instead of connecting to the local IRTrans server on the HS3 system).
            #65
            Urgent - critical
            Hi Yoyo,
            Bad news, the plugin has expired another time at midnight and blocks a big part of my system
            When will you put it in updater ?
            Could you please send a new version ?
            Thanks in advance.
            Yves
              #66
              Love to pay
                #67
                Ouch, same here ;-) Complaints from the wife and I'm out of the country
                  #68
                  Please make it available in the store!
                  Zefram
                    #69
                    license needed
                    Same issue here , the software is fully stable, but the trial license expired. I have no issue to pay for this, can you quickly publish it on homeseer or extend the trail for a longer period ?
                    cheers,
                    Didier
                      #70
                      Same here. Portion of my house functionality is now down.
                      Great plugin. Ready to pay.
                      tenholde
                      tenholde
                        #71
                        Same here......
                        Would appreciate an update Brian.
                        IRtrans plays a key part in my system.
                        your call which way to go; updater or trial extension.
                        Appreciate your support
                        Evja
                          #72
                          Sorry about that... I'm posting an updated exe that will get you to November 2016.
                          I did submit a request to HS back in October, but it apparently was missed. I guess I'll have to try again.
                          Note: this attachment only contains the exe, so just replace the current one; nothing else has changed.
                            #73
                            Thanks YoYo!! Lets hope we can buy it soon
                              #74
                              Thank you sir !
                              Great reliable plugin.
                              Might as well try to get it into the updater and make a few $$.
                              I am sure many are willing to pay.
                              Cheers,
                              evja
                                #75
                                Thanks. Up and running again.
                                Let us know when we can pay you,
                                tenholde
                                tenholde
