So I'm running HS2 with ISY Insteon and have been for a few years now. I've been very happy with the products.
I mostly use ISY for my HA but I use HS for voice prompts etc.
I've been changing my method of triggering voice prompts in HS from ISY and have been trying to simply set an integer variable value in ISY to trigger a voice output.
So - in ISY there's a variable called 'say car in driveway' with a value of zero. When a car is detected in the driveway it changes the value to 1 for 30 seconds and then back to 0.
In Homeseer I have an event based on the ISY variable which says 'when ISY Variable 'say car in driveway' equals 1 then speak the message 'car in driveway'.
That works.
But it also speaks the message when it toggles the value back to 0 or 9 or -117. Any change in value triggers the event.
Any idea what I might be doing wrong?
mark
That works.
mark
