I have the 1.1.0.0 plug-in installed with HS3 windows. I have four thermostats setup and working.
I'm interested in setting an event to handle turning on a ceiling fan in the middle of the night if it's hot outside.
One problem, when I set up the event and use "If device has a value set and is greater than..." there are multiple "Indoor Temp" values. Likewise Fan Mode, Fan Status, Hold Type, Operating Status and the rest. They're all labeled the same, but are obviously for different thermostats.
I have each thermostat named. Those names do appear in the drop-down, along with all my other devices. All of those menu entries have names based on concatenated strings. Like "1st Floor Living Room 1st Floor Thermostat" which is based on "1st Floor" being the floor value, "Living Room" being the room and "1st Floor Thermostat" being the name, as set in the device details for the thermostat.
It'd be helpful to know which device is associated with each value.
Meanwhile I'm open to suggestions/warnings/other advice on how to best implement this kind of event.
