I have a Schlage BE468 (A BE469 w/o alarm) that I can control from hstouch using a script that makes a CAPI call to toggle the lock from locked to unlocked or vice versa each time it is called. This script works great.
There is an issue when the lock is manually unlocked as summarized below:
1. Manually unlock the lock, value changes to unlocked (0) as expected
2. Z-Wave makes a log entry that the lock was Set to Unlocked
3. Make CAPI call to lock the lock changes the value to locked (255), but the lock physically remains unlocked.
4. Make CAPI call to unlock the lock changes the value to unlocked(0) and the lock remains physically unlocked
5. Make CAPI call to lock the lock and the value changes to locked(255) and the lock does physically lock
6. All additional CAPI calls operates the lock as expected until the lock is manually unlocked and then the issue repeats as above.
I do not understand why the CAPI call to lock the lock does not work after the lock is manually unlocked.
