Looks like you've got the results of two separate adds there. If you don't want to go through it again, just hold tight and see which set is valid and working; then delete the others. It'll sort itself out in about 24 hours. Afterward you can rename the good ones and even change the device codes and location if you like.
ZSmoke!
Using "ZSmoke Interpretation.vb" on my H2, should I be looking for a value change to the Root or to the Alarm for my Event?
If I press the Test button (setting off the alarm) should that fire the event? So far I have not seen the "Last Changed" time change at all, even when Testing the alarm. (Root says "Never Set", Alarm says "Today 12:51:02 PM" and Battery says "Today 12:51:03 PM", which are the Add times).
PS: Thanks all for the help...you make this the best info Forum out there!
Heh heh heh
Originally posted by Wadenut View PostHere's a script (in progress) to give some support for these units to HS2. Instructions are in the script ...Originally posted by Wadenut View PostOK. I have updated the script above. Treat this as a completely different item as the event definitions have changed..Code:[SIZE=2][COLOR=#d58000]Warning [/COLOR][/SIZE][SIZE=2][COLOR=#d58000]Garage Smoke Detector heartbeat has not been seen since ...[/COLOR][/SIZE]
Greg, have a chuckle on me! Thanks for all your hard work regardless!Steve
(System configuration is in my profile)
So I had one of my zmoke chirping for low battery this morning when I woke up. I was surprised because in looking at the batter child, it reported 70% or so of battery life last night. Has anyone actually seen the battery level report low so you can anticipate the battery swap?
On a side note, I just changed the batteries and I didn't have to re-add to my zwave network... (always wondered what would happen on these when the battery died or when they are taken out and re-added)
RobHS3PRO 3.0.0.500 as a Fire Daemon service, Windows 2016 Server Std Intel Core i5 PC HTPC Slim SFF 4GB, 120GB SSD drive, WLG800, RFXCom, TI103,NetCam, UltraNetcam3, BLBackup, CurrentCost 3P Rain8Net, MCsSprinker, HSTouch, Ademco Security plugin/AD2USB, JowiHue, various Oregon Scientific temp/humidity sensors, Z-Net, Zsmoke, Aeron Labs micro switches, Amazon Echo Dots, WS+, WD+ ... on and on.
Originally posted by langenet View PostSo I had one of my zmoke chirping for low battery this morning when I woke up. I was surprised because in looking at the batter child, it reported 70% or so of battery life last night. Has anyone actually seen the battery level report low so you can anticipate the battery swap?
Rob
I have one of these, but I have also not done a self test in many months. Oops. If only we had some kind of automation system that could remind us once a month.
Well...I'm not sure about that as I have watched the percentage of battery life go down a little since I put them in service....HS3PRO 3.0.0.500 as a Fire Daemon service, Windows 2016 Server Std Intel Core i5 PC HTPC Slim SFF 4GB, 120GB SSD drive, WLG800, RFXCom, TI103,NetCam, UltraNetcam3, BLBackup, CurrentCost 3P Rain8Net, MCsSprinker, HSTouch, Ademco Security plugin/AD2USB, JowiHue, various Oregon Scientific temp/humidity sensors, Z-Net, Zsmoke, Aeron Labs micro switches, Amazon Echo Dots, WS+, WD+ ... on and on.
I've found the battery reports about every time the unit checks in... a little more than an hour.
On the battery, I put a new battery in about a month ago, at about 75%. It ran for a couple of weeks before it started chirping again. It's in the garage, and I haven't been working out there much lately, so I've just left it alone this time. It's currently showing 77%.Real courage is not securing your Wi-Fi network.
Huh, well I was totally off on that one. It must be that the updates will not route, and must need to be directly picked up by the ztroller or whatever zwave interface one has. Mine has not shown an update in a while, but I have had the ztroller on that end of the house disconnected due to some house work for a few months. Or it might be that I never put new batteries in that one a few months ago when it started low battery chirping...I don't recall. Too many projects ongoing.
Yeah.. I think mine was about 77% as well. I was kinda expecting the battery to start chirping around 5%... oh well...HS3PRO 3.0.0.500 as a Fire Daemon service, Windows 2016 Server Std Intel Core i5 PC HTPC Slim SFF 4GB, 120GB SSD drive, WLG800, RFXCom, TI103,NetCam, UltraNetcam3, BLBackup, CurrentCost 3P Rain8Net, MCsSprinker, HSTouch, Ademco Security plugin/AD2USB, JowiHue, various Oregon Scientific temp/humidity sensors, Z-Net, Zsmoke, Aeron Labs micro switches, Amazon Echo Dots, WS+, WD+ ... on and on.
Well... this is the first battery change since I got these at almost exactly one year ago... not too bad I suppose.HS3PRO 3.0.0.500 as a Fire Daemon service, Windows 2016 Server Std Intel Core i5 PC HTPC Slim SFF 4GB, 120GB SSD drive, WLG800, RFXCom, TI103,NetCam, UltraNetcam3, BLBackup, CurrentCost 3P Rain8Net, MCsSprinker, HSTouch, Ademco Security plugin/AD2USB, JowiHue, various Oregon Scientific temp/humidity sensors, Z-Net, Zsmoke, Aeron Labs micro switches, Amazon Echo Dots, WS+, WD+ ... on and on.
nostep
AlarmType codes
Good info in this thread such as that AlarmType is 1 for Smoke and 2 for CO. Does anyone know what codes 22 and 90 are? I got those codes two nights apart with no chirp.
Is the general consensus that these units are worthwhile? I have a couple of ZCOMBO units that I got recently, but haven't installed them yet. Our old carbon monoxide detectors went beyond their rated life (apparently the detection element has a finite life of 3-5-7 years or something), so picked up the Z-Wave units for a fun test.
