I'm currently evaluating BLStat . . . before I pull the trigger and purchase, I'd like to resolve these two error messages that are popping up. How do I fix them?
Error/warning messages in log
Originally posted by Blade View PostYou will have to connect as an admin user and remove the files and make sure BLStat is not enabled. I have never used a Hometroller before so you may have to ask others how to do that
Also, Hometroller is no different than any other Linux install, so if you can tell me how to connect as an admin, I should be able to do that.
OK, I rooted in and deleted everything that looked relevant. Still getting the errors. Take a look at these two log screens.
Is SqLite.Interop.dll something that comes with HS3, or is that something your plug-in installs? If it's not required by HS3 other than for your plug-in, I can delete it and do another re-install. If it is required, then there is some incompatibility between the plug-in and HS3's core files.
Yes they do. And I still have the error messages. I contact HomeSeer support, and they say that there's something wrong with the plugin code as to why it's not reinstalling properly.
I appreciate your help on this, but, truth to told, the inability to get this plugin working has left a bad taste in my mouth for your plugins -- I was thinking of getting about a half-dozen based on the functionality, but if I can't even get the first one working, well . . . . .
Going to shelve this project for now, and will stick with using events in HS3 to control my thermostats. Sorry.
