Hi All, I'm new to z-Wave and having a real challenge with getting a Zooz ZSE09 Mini Sensor to trigger an event. (I'm using current version is: HS3 ZEE S2 Edition 3.0.0.297 if that helps.)
Is anyone successfully using a HTZ and a Zooz ZSE09?
I've been trying to follow rprade's outstanding post on setting up motion detector events: https://forums.homeseer.com/showthread.php?t=172120
(I don't need the lighting only during evening and night hours and disable it when there is adequate ambient light parts as they don't apply in my context.) rprade's post is excellent and has gotten me much farther than I was getting on my own, but I'm still not at 100% success yet.
The Zooz ZSE09 seems to have installed fine and I can see it in the Device Manager. I've even gotten an Event for On and Off created and when I use the "Run Event Actions" in the events both On and Off work - since the "Run Event Action" skips the trigger I suspect that may be where my problem is, but I have tried multiple variables and cannot seem to find the right combination.
I've attached a screen shot of the On event - does anyone have a suggestion?
Thanks, in advance for any help!
[Just venting - I've spent 4 days on this so far and frustrated as heck. My old x10 system was 1000x easier to set up even if it wasn't as reliable.]
Oh, being new I forget to include:
Current Date/Time: 1/21/2017 10:25:05 PM
HomeSeer Version: HS3 ZEE S2 Edition 3.0.0.297
Linux version: Linux HomeTrollerZeeS2 3.18.11-v7+ #781 SMP PREEMPT Tue Apr 21 18:07:59 BST 2015 armv7l GNU/Linux System Uptime: 21 Days 8 Hours 33 Minutes 17 Seconds
IP Address: 192.168.1.239
Number of Devices: 44
Number of Events: 23
Available Threads: 399
Enabled Plug-Ins
3.0.0.68: HSTouch Server
3.0.6167.15622: UltraWeatherWU3
3.0.1.87: Z-Wave
Enabled Plug-Ins
3.0.1.87: Z-Wave
