Having trouble getting to the WU station I want...
    Hi all, I've done some searching but haven't found a solution here.
    The station I want to use is here: https://www.wunderground.com/cgi-bin...ast?query=KHWD
    But I can find no way to add it. IT would be really nice if there was a way to just type in a station ID rather than needing to pull down from a list.
    HomeSeer Version: HS3 Pro Edition
    Operating System: Microsoft Windows 10 Pro
    Processor Type and Speed: i7 - 3.26 GHz
    Total Physical Memory: 16Gig
    Plugins: BlBackup | EasyTrigger | FitbitSeer | HSTouchServer | Insteon | WeatherXML
    Even if I did make it so you can type in a code, it wouldn't work.
    I tested the results using that station code and there is no current condition info provided in the API call. I suspect that if the stations are not in the list provided by WU, then that station does not use the API format.
    Jeff Farmer
    HS 3, HSPhone
      OK, thanks for checking. It's a shame because it's an airport that is less than a mile from me. The weather info is always way more accurate then the other stations near me.
      Tony
