Same here, trying to find out what that button is called so that I can have an event do a press it at night to black out the screens.
How to change an HSTouch screen dim script to work in HS3?
Tom
baby steps...starting again with HS3
HS3Pro: Z-NET & 80 Z wave Devices,
HSTouch: 4 Joggler (Android Kitkat), 2 iPhone, 3 iPads
Whole House Audio: 5 SqueezePlay Jogglers w Bose Speakers
In The Works: 10 Cameras Geovision, new Adecmo/Envisalink Alarm, Arduinos
System: XP on Fanless Mini-ITX w/ SSD
My button is called "power", and is placed on the screen "Hovemeny" (main menu).
It's called like this:
On Android clients the "power" button release action sets the dim level to 0.
On Windows clients the "power" button release action runs this command: "nircmd.exe monitor off"
Nircmd is found here:
http://www.nirsoft.net/utils/nircmd.htmlHSPro 3.0.0.458, Z-NET with Z-wave plugin 3.0.1.190, RFXCOM + 2x RFXtrx433E, HSTouch, Squeezebox plugin, iTach IP/WF2IR & GC-100-6 with UltraGCIR, BLDenon, NetcamStudio, Jon00s Webpage builder, Harmony Hub plugin, SCSIP (with FreePBX), Arduino plugin, IFTTT, Pushalot plugin, Device History plugin.
Running on Windows 10 (64) virtualized on ESXi (Fujitsu Primergy TX150 S8).
Moskus,
Thank you for your follow up.
My home screen is just called "Home" but "Homeower" doesn't seem to work. I'm really not sure what that gear like button on the bottom left does, but I don't believe it is a dim level. Using your script I've done dim of 0(lots of light from screen) and its not the same as when I press the gear button(complete blank dark screen).
I'm gonna seek if Rich could shed some light on this, because these new screens are super bright a night.Tom
Thanks.
So your using the old hstouch templates I assume and not the latest version of android client?Tom
Yup,
Yeah I redownloaded the Designer and didn't find the lastest Android template at all. But it doesn't matter if that "gear" like icon was not there.
Got too many other small projects going on now, but will have to make hidden button with blank page as soon as I get some time.
Thank you for your replies!Tom
Check this directory for win7 machines if you have the designer installed:
The button's "Actions when pressed" are loading a new screen with the background set to black (like what in4ni did) with a blank image that when pressed, brings you back to the home screen. There's also a Misc action "Set Screen Brightness" which is used on both screens to lower and brighten the screen accordingly.
The problem I find with this feature is that your screen isn't actually sleeping - it's still on.
I found a nifty little app in the Android store called "Screen Standby" which is very effective. It allows your screen to turn-off (not just dim) but will not put the tablet to sleep. It also allows the screen to wake when tapping anywhere on the screen. I don't use it on my mobiles, but it's very effective on Android tablets designated for HSTouch.
Originally posted by Krameduoh View PostCheck this directory for win7 machines if you have the designer installed:
I found a nifty little app in the Android store called "Screen Standby" which is very effective. It allows your screen to turn-off (not just dim) but will not put the tablet to sleep. .
Good point about the screen not sleeping. Screen Standby is probably a better option. Will check this out.
Thank you again!Tom
Event Action - HSTouch Actions > Simulate Press of an Element > Element Name: Home:__?__ (just need the name of the button)
Or What is the name of the new blank screen called. I could call this
Event: Hstouch Actions > Display Screen By Itself > (SCREEN NAME)
Again for some reason I don't have these new templates in my designer so can't look any of this up.Tom
Thank you Mark or karm!
that did it! Been looking for two weeks. For what ever reason many of us still dont have that gear icon or the sleep screen even with the latest designer. I had almost given up.
sleep screen with screen standby app will be a great fit.Tom
Mark was able to find the screen. its called "Sleep"
http://board.homeseer.com/showpost.p...2&postcount=11Tom
